[GRASS5] configure-problem on linux and irix
there must be some small errors with configure.
configure no longer finds GLwMDrawA.h, which was found with the same
setup once before (file irix-configure contains all switches i used to
compile a perfectly working bin installation on irix 6.5/with gcc).
And there must be some typo around line 3404 in configure.
Please see the attached files.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
(attachments)
irix-configure.txt (392 Bytes)
config.err.txt (3.21 KB)
On Sat, Jan 06, 2001 at 02:00:34PM +0100, Andreas Lange wrote:
./configure --bindir=/usr/people/andreas/bin \
--enable-postgres=no \
--with-jpeg-includes=/usr/freeware/include \
--with-jpeg-libs=/usr/freeware/lib32 \
--with-tiff-includes=/usr/freeware/include \
--with-tiff-libs=/usr/freeware/lib32 \
--with-tcltk-includes=/usr/freeware/include \
--with-tcltk-libs=/usr/freeware/lib32 \
--with-opengl-includes=/usr/include \
You can leave this off or make it /usr/include/GL and it should work.
It should have never worked before, since "GL" isn't appended when the
directory is specified.
--with-opengl-libs=/usr/lib32
[snip]
checking TIFF include dirs... -I/usr/freeware/include
checking additional TIFF library dirs... -L/usr/freeware/lib32
checking for TIFFOpen in -ltiff... yes
checking Tcl include dirs... -I/usr/freeware/include
./configure[3404]: test: argument expected
I looked, but couldn't find anything. I don't see that error here, even
when I specify --with-tcltk-includes=/usr/include/tcl8.3. All the
"test" calls have arguments (though some, of course, may have empty
values).
checking Tk include dirs... -I/usr/freeware/include
checking additional Tcl and Tk library dirs... -L/usr/freeware/lib32
checking for Tk_MainWindow in -ltk8.0... yes
checking GL/gl.h and GL/GLwMDrawA.h... configure: warning: *** Didn't find GL/GLwMDrawA.h
-I/usr/include and
See above.
checking for glBegin in -lGL... yes
checking for gluBeginCurve in -lGLU... yes
checking for GLwDrawingAreaMakeCurrent in -lGLw... no
checking for GLwCreateMDrawingArea in -lGLwM... no
I'm not sure what's up with these last two. They can fail if X_LIBS
isn't set correctly. It's possible I need to add the X_PRE_LIBS as well
(X_LIBS and X_PRE_LIBS being set by the AC_XTRA macro).
Eric G. Miller <egm2@jps.net>
subject 'unsubscribe grass5'
Hi Eric and Andreas
even when I specify --with-tcltk-includes=/usr/include/tcl8.3. All
the "test" calls have arguments (though some, of course, may have
empty values).
I found what is causing the problem. The line it refers to is
if test $tkincdir && test -z $HAVE_TK_H ; then
and $HAVE_TK_H is empty at that point. I don't know why it is empty but
this is what is causing the error.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
On Mon, Jan 08, 2001 at 02:23:17PM +0700, Justin Hickey wrote:
Hi Eric and Andreas
> empty values).
Ahh, yes. Someone other than myself commented out the portion of
configure.in that would've set that variable... Will fix.
Hi Eric
> but this is what is causing the error.
Sorry, but I still get the error message after updating configure.in,
running autoconf, removing config.cache, and running configure. My
experience has been that variables somtimes need to be inside "" to work
as expected on some systems. What about trying "$HAVE_TK_H"?
Sincerely,
Bangkok, Thailand
On Tue, Jan 09, 2001 at 12:07:27PM +0700, Justin Hickey wrote:
Hi Eric
Hmm, well it would seem such an error would crop up elsewhere as well.
Anyway, why don't you try out some of your ideas. I can't reproduce the
problem here, so it's hard for me to find a solution. That whole
$HAVE_TK_H could probably be removed anyway since the code that would've
set it has been commented out.
Hi Eric
the problem here, so it's hard for me to find a solution. That whole
would've set it has been commented out.
The ""'s worked, but since HAVE_TK_H is commented out I removed them as
well as HAVE_TCL_H. Commiting changes now.
Thanks for the tip.
Sincerely,
Bangkok, Thailand
Thanks a lot for looking at the problems.
> -I/usr/include and
See above.
the last two checks fail on linux too with the same message. And i
didn't specify any paths except --with-tcltk-includes=/usr/include
--with-tcltk-libs=/usr/lib (this is still neccessary and i wonder why?).
But i can not check as my CVS doesn't compile any longer.
cu,
Andreas
> > -I/usr/include and
> See above.
I don't know why you'd need to specify the tcltk things. Those paths
are both in the default search paths.
As far as the GLw... stuff, my guess is the LDFLAGS needs $X_PRE_LIBS
added but I don't know for sure. It seems most likely that there are
additional linker flags needed for the library check which are currently
not being specified. I just don't know which flags are needed.
Hi again,
> > > -I/usr/include and
> > See above.
Eric, do you have a hit for me on this one
(r.showdspf.opengl compiled fine for the last month, I can't remember that I
changed anything related on my Linux machine):
src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL > gmake5
gcc -s -o /home/neteler/ggg/dist.i686-pc-linux-gnu/etc/bin/cmd/r3.showdspf
OBJ.i686-pc-linux-gnu/new_init_graphics.o OBJ.i686-pc-linux-gnu/cap_data.o
OBJ.i686-pc-linux-gnu/init_caps.o OBJ.i686-pc-linux-gnu/debugf.o
OBJ.i686-pc-linux-gnu/do_color_ogl.o OBJ.i686-pc-linux-gnu/get_color_ogl.o
OBJ.i686-pc-linux-gnu/draw_cap_ogl.o OBJ.i686-pc-linux-gnu/draw_polys_ogl.o
OBJ.i686-pc-linux-gnu/draw_cappolys_ogl.o
OBJ.i686-pc-linux-gnu/thresh_array.o OBJ.i686-pc-linux-gnu/make_header.o
OBJ.i686-pc-linux-gnu/r3_data.o OBJ.i686-pc-linux-gnu/r3_find.o
OBJ.i686-pc-linux-gnu/togif.o OBJ.i686-pc-linux-gnu/Ball.o
OBJ.i686-pc-linux-gnu/BallAux.o OBJ.i686-pc-linux-gnu/BallMath.o
OBJ.i686-pc-linux-gnu/main_ogl.o -I/home/neteler/ggg/src/libes/dspf
-I/home/neteler/ggg/src/libes/ogsf -I/usr/include/GL -I/usr/X11R6/include/GL
/home/neteler/ggg/src/libes/dspf/LIB.i686-pc-linux-gnu/libdsp3.a
/home/neteler/ggg/src/libes/LIB.i686-pc-linux-gnu/libg3d.a
/home/neteler/ggg/src/libes/LIB.i686-pc-linux-gnu/libdatetime.a
/home/neteler/ggg/src/libes/LIB.i686-pc-linux-gnu/libgis.a -lGLU -lGL -lGLw
-lXm -lX11 -lXt -lXext -L/usr/X11R6/lib -L/lib -lm -lz
OBJ.i686-pc-linux-gnu/new_init_graphics.o: In function 'init_graphics':
/home/neteler/ggg/src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL/new_init_graphics.c:570:
undefined reference to 'GLwCreateMDrawingArea'
/home/neteler/ggg/src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL/new_init_graphics.c:629:
It must have something to do with configure.
(config.cache removed):
configure
checking GL/gl.h and GL/GLwMDrawA.h... -I/usr/include/GL and -I/usr/X11R6/include/GL
checking for GLwDrawingAreaMakeCurrent in -lGLw... yes
grep GLwCreateMDrawingArea /usr/lib/libGLw.so.3.0
Übereinstimmungen in Binärdatei /usr/lib/libGLw.so.3.0.
   |-> matches in binary file
So GLwCreateMDrawingArea is there...
Any ideas?
configure
Any ideas?
Nope. I just did a cvs update a few hours back, did a make distclean,
ran configure, and built it just fine... Like I've said, I think the
problem lies in missing flags for configure (specifically -L and -l
types) for some segment of X and Motif/Lesstif. Whatever they are, I
don't need them so I can't figure out what they are. Try adding the
$X_PRE_LIBS to the $LD_FLAGS=... part of configure.in just before the
AC_CHECK_LIB(GLwM,...). The $X_PRE_LIBS should be defined by the
AC_XTRA macro (it's results are already used in src/CMD/head/head.in).
On a related note, I've noticed many of the G3d public functions don't
have prototypes in G3d.h. This may be related to some other problems
with programs such as r3.out.vis5d. I don't know why some are declared
and others are not -- and I am talking about just the public functions
(as described in the programming manual).
