[GRASS5] configure question: GD lib versions
Folks,
on my machine are both GD1.8 and 2.x present. For compatibility
reasons the 1.8 version must stay, it is in /usr/lib/
The libgd.so.2 is in /usr/local/lib (both the gd.h accordingly).
Now the question: How can I convince configure/PNGdriver to pick up
the libgd.so.2? Of course I tried the related parameter, but probably
due to the LD_LIBRARY_PATH order the PNG driver (ldd tested) finally
takes the gd1.8.
I solved it by hacking libgd.so.2 directly into the head.i686* file,
but that's not really the best. On the other hand I could not
directly specify the libgd.so.2 as configure parameter (probably
autoconf doesn't allow for this as only directories are allowed here).
Maybe I am overseeing a trick to specify libgd.so.2 to avoid manual
editing the head file? Or is my problem just too specific?
I have basically the same setup; GD-1.3 in /usr/{include,lib},
GD-2.0.1 in /usr/local/{include,lib}:
-rw-r--r-- 1 root root 5404 Feb 3 2000 /usr/include/gd.h
-rw-r--r-- 1 root root 421 Feb 3 2000 /usr/include/gdfontg.h
-rw-r--r-- 1 root root 419 Feb 3 2000 /usr/include/gdfontl.h
-rw-r--r-- 1 root root 382 Feb 3 2000 /usr/include/gdfontmb.h
-rw-r--r-- 1 root root 383 Feb 3 2000 /usr/include/gdfonts.h
-rw-r--r-- 1 root root 415 Feb 3 2000 /usr/include/gdfontt.h
lrwxrwxrwx 1 root root 12 Jan 26 2001 /usr/lib/libgd.so -> libgd.so.1.2
lrwxrwxrwx 1 root root 12 Jan 26 2001 /usr/lib/libgd.so.1 -> libgd.so.1.2
-rwxr-xr-x 1 root root 156353 Feb 3 2000 /usr/lib/libgd.so.1.2
-rw-r--r-- 1 root root 19226 Oct 15 19:56 /usr/local/include/gd.h
-rw-r--r-- 1 root root 917 Oct 15 19:56 /usr/local/include/gd_io.h
-rw-r--r-- 1 root root 2673 Oct 15 19:56 /usr/local/include/gdcache.h
-rw-r--r-- 1 root root 490 Oct 15 19:56 /usr/local/include/gdfontg.h
-rw-r--r-- 1 root root 488 Oct 15 19:56 /usr/local/include/gdfontl.h
-rw-r--r-- 1 root root 451 Oct 15 19:56 /usr/local/include/gdfontmb.h
-rw-r--r-- 1 root root 452 Oct 15 19:56 /usr/local/include/gdfonts.h
-rw-r--r-- 1 root root 484 Oct 15 19:56 /usr/local/include/gdfontt.h
lrwxrwxrwx 1 root root 29 Oct 15 19:56 /usr/local/lib/libgd.so -> /usr/local/lib/libgd.so.2.0.0
lrwxrwxrwx 1 root root 29 Oct 15 19:56 /usr/local/lib/libgd.so.2 -> /usr/local/lib/libgd.so.2.0.0
-rwxr-xr-x 1 root root 452267 Oct 21 19:55 /usr/local/lib/libgd.so.2.0.0
[In spite of the library versions, the GD package versions really are
1.3 and 2.0.1 respectively.]
takes the gd1.8.
./configure ... \
  --with-gd-includes=/usr/local/include \
  --with-gd-libs=/usr/local/lib
works fine for me.
For completeness, the exact configure command which I use is:
./configure --prefix=/opt --bindir=/usr/local/bin \
  --with-gdal --with-blas --with-lapack --with-motif --with-freetype \
  --with-dbm-includes=/usr/include/gdbm \
  --with-freetype-includes=/usr/X11R6/include/freetype2 \
  --with-freetype-libs=/usr/X11R6/lib \
  --with-postgres-includes=/usr/include/pgsql \
Note: LD_LIBRARY_PATH won't affect which version is used; the two
libraries will have different sonames (libgd.so.1 vs libgd.so.2).
$ ldd /opt/grass5/driver/PNG
  libgd.so.2 => /usr/local/lib/libgd.so.2 (0x4001b000)
  libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x40057000)
  libSM.so.6 => /usr/X11R6/lib/libSM.so.6 (0x40065000)
  libICE.so.6 => /usr/X11R6/lib/libICE.so.6 (0x4006f000)
  libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x40087000)
  libfreetype.so.6 => /usr/X11R6/lib/libfreetype.so.6 (0x40146000)
  libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40182000)
  libpng.so.2 => /usr/lib/libpng.so.2 (0x401a1000)
  libm.so.6 => /lib/libm.so.6 (0x401cb000)
  libc.so.6 => /lib/libc.so.6 (0x401e8000)
  libdl.so.2 => /lib/libdl.so.2 (0x402de000)
  libz.so.1 => /usr/lib/libz.so.1 (0x402e2000)
  /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
The directory switches should suffice. You aren't explicitly
specifying /usr/include or /usr/lib with any switches, right?
What do you get in the configure output, and in config.log?
For me, it doesn't detect the GD library until the 16th (i.e. final)
attempt[1] (it attempts the 16 possible combinations of X11 (for Xpm),
freetype, JPEG and PNG in order to obtain a successful link).
[1] In my case, I intentionally didn't add any dependency information
when building GD, to ensure that configure would work without it.
