[GRASS5] Configure Warning
Hi Eric,
FYI, this snip from my config output seems odd to me:
checking Tcl include dirs... -I/usr/local/include
checking Tk include dirs... -I/usr/local/include
checking Tcl/Tk library dirs... -L/usr/local/lib
checking for Tk_MainWindow in -ltk8.0... no
configure: warning: *** Failed to find Tcl/Tk libraries
It finds the Tcl/Tk libs, but reports it doesn't.
Yours,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
On Mon, Jan 29, 2001 at 07:05:01PM -0800, Jeshua Lacock wrote:
Hi Eric,
An unending burr in my britches... :wink:
I'm guessing you get that with a clean slate (i.e. does removing
config.cache and re-running ./configure make a difference) ?
Probably another library is needed for 'ld' in the test script that is
generated. Is Tk tied into the native GUI on OS X? or is it tied to
XFree86? Could make a difference...
Maybe:
$ ldd /usr/lib/libtk8.0.so
will tell you (won't work on ar archives [*.a]).
Eric G. Miller <egm2@jps.net>
Hi Eric,
Hi from here,
a similar thing happens on SUN Solaris:
creating cache ./config.cache
checking host system type... sparc-sun-solaris2.6
configure: warning: *** Could not find tcl/tk library.
checking for Tk_MainWindow in -ltk8.0... yes
But I have:
/usr/lib/libtcl8.0.so
Strange...
BTW: Jeshua, do you have "tcltkgrass" running?
Regards
Yes :smiley:
Jeshua Lacock
Cartographer/Owner
---------------------------------------- If you want to unsubscribe from GRASS Development Team mailing list write to:
