[GRASS5] counting number of vector points in same position?
I have to transform a vector points map of disease reports.
Often more than one report falls into the same location as
reports were done/geocoded based on cities. This results into
a vector map with often several vector falling into the
same coodinate pair.
I have to transform this map into a new vector map with
single point per coordinate pair and number of cases as
attribute.
How to do that?
I was thinking of v.distance -a to calculate zero-distances.
This requires to exclude that the points "see" themselves.
But then, I am not sure how to transform this into a map.
Maybe with some SQL fun (distinct() operator or so)?
Suggestions welcome. This functionality appears to me to
be needed for GRASS. I darkly remember that it was asked
time ago, but cannot find the mail(s).
Thanks
On Wed, 10 Aug 2005, Markus Neteler wrote:
attribute.
How to do that?
If you can move the points into R:
xcoord <- runif(300)
ycoord <- runif(300)
reps <- 1+rbinom(300, 3, 0.3)
table(reps)
reps
  1 2 3 4
96 132 66 6
crds <- cbind(rep(xcoord, reps), rep(ycoord, reps))
crds_s <- crds[sample(nrow(crds)),]
replicates your problem, here 582 points for 300 unique locations, in
random order.
u_crds_s <- unique(crds_s)
cnts <- integer(nrow(u_crds_s))
for (i in 1:nrow(u_crds_s)) cnts[i] <- length(which(apply(crds_s, 1,
+ function(x) identical(x, u_crds_s[i,]))))
table(cnts)
cnts
  1 2 3 4
96 132 66 6
res <- cbind(u_crds_s, cnts)
then export res back to GRASS maybe as a shapefile. If the coordinates
have ID tags, matching would be easier, but this works for non-fuzzy
coordinates. If the coordinates need snapping, all.equal() with a
tolerance could be used instead of identical, but it is much slower.
Hope this helps,
Roger
Thanks
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand@nhh.no
Hi, Markus.
If your points have the exact same coordinate, you might v.out.ascii then stg
like 'awk -F"|" {print $1 " " $2} | sort -n | uniq -c' on the output file,
then v.in.ascii back. If you have a tolerance radius for "same location", some
rounding tweaking might be needed.
Daniel.
---------- Original Message -----------
To: grass5 developers list <grass5@grass.itc.it>
Sent: Wed, 10 Aug 2005 18:35:51 +0200
Subject: [GRASS5] counting number of vector points in same position?
attribute.
How to do that?
Thanks
grass5 mailing list
grass5@grass.itc.it
------- End of Original Message -------
If v.neighbors had other statistical functions besides count (e.g., sum,
mean, max, min), you could sum cases for all points within a raster cell.
Then you could transform it back to vector.
Michael
On 8/10/05 9:35 AM, "Markus Neteler" <neteler@itc.it> wrote:
attribute.
How to do that?
Thanks
> Hi,
> attribute.
> How to do that?
> table(reps)
reps
  1 2 3 4
96 132 66 6
random order.
> table(cnts)
cnts
  1 2 3 4
96 132 66 6
Hope this helps,
Thanks, Roger.
I have tried your example successfully. On the (new) destination
machine I still have to install R to perform it there.
On Wed, Aug 10, 2005 at 01:15:54PM -0500, Daniel Calvelo Aros wrote:
Hi, Markus.
Hi Daniel,
like this it is amazingly simple:
v.out.ascii tbe_cases_bite | awk -F"|" '{print $1 " " $2}' | sort -n | uniq -c |\
     awk '{printf "%f|%f|%d\n", $2, $3, $1}' | \
     v.in.ascii out=tbe_cases_bite_numbers cat=0 column="east double, north double, count integer"
Done. Maybe worth a script in GRASS (v.pnt.count or so)? Only an extra test
for 3D points is needed to be added.
BTW: I have fixed v.in.ascii for LatLong vector points where it bailed out
with an error.
Thanks
Thanks, Michael,
in my case I cannot limit to underlying raster cells.
Inspired by s.cellstats [1] I tried to update it to v.cellstats which is
doing what you mention above (but writing vector).
Do we want v.cellstats? This needs help of someone more
familiar with DBMI programming than me.
[1] http://grass.itc.it/gdp/html_grass5/html/s.cellstats.html
V.cellstats would be very helpful. As you say, its functionality would be
roughly equivalent to an improved v.neighbors. An improved v.neighbors would
still be nice too, as it does something a little different.
Michael
Thanks, Michael,
1) v.clean rmdupl will remove duplicates and it should attache
    all cats to one point (-> one-many link between geometry and attributes)
2) v.category layer=2 (-> new layer with 1 cat/point)
3) create and link new table to layer 2
4) v.to.db option=query layer=2 qlayer=1
    (query attributes in layer 1 and uppload to layer 2)
Radim
On 8/10/05, Markus Neteler <neteler@itc.it> wrote:
attribute.
How to do that?
Thanks
grass5 mailing list
grass5@grass.itc.it
Thanks Radim. This is helpful. This is also the first example I've seen of
the query option for v.to.db.
Could you explain how it works in a bit more detail.
Thanks.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Date: Tue, 16 Aug 2005 10:36:23 +0200
Subject: Re: [GRASS5] counting number of vector points in same position?
Radim
attribute.
How to do that?
Thanks
grass5 mailing list
grass5@grass.itc.it
Radim,
thanks for your example. I took the occasion to write the scripts:
  v.db.addtable help
    adds a new attribute table to a given layer of a vector map
and
  v.db.droptable help
    removes existing attribute table of a vector map
Trying to make an example out of below sketch, I finally failed:
# Generate 3 points in the same place (Spearfish60):
echo "599505|4921010|1
599505|4921010|2
599505|4921010|3" | v.in.ascii out=triple
# remove duplicates from map:
v.clean triple out=triple_simple tool=rmdupl
# ... remaining: one2many link between geometry and attributes
# verify categories:
v.category triple_simple op=report
LAYER/TABLE 1/triple_simple:
type count min max
point 3 1 3
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
all 3 1 3
# add new layer with 1 cat/point:
v.category triple_simple out=triple_simple_multi layer=2
# create and link new table to layer 2:
v.db.addtable triple_simple_multi layer=2 columns="cat integer, count integer"
v.info -c triple_simple_multi layer=2
# upload number of identical vector points to attribute table:
v.to.db triple_simple_multi option=query layer=2 qlayer=1 column=count
Reading data trom the map ... 100%
Querying database ... 100%
DBMI-DBF driver error:
SQL parser error in statement:
SELECT (null) FROM triple_simple_multi WHERE cat = 2 OR cat = 1 OR cat = 3
Error in db_open_select_cursor()
ERROR: Cannot open cursor: 'SELECT (null) FROM triple_simple_multi WHERE
        cat = 2 OR cat = 1 OR cat = 3'
Perhaps you can identify the mistake in the procedure.
Thanks
Radim
> Hi,
> attribute.
> How to do that?
> Thanks
> Markus
> grass5 mailing list
> grass5@grass.itc.it
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
qcolumn option is missing, it should be 'count(*) in this case, but it can be
expression supported by database driver, for example sum(colum_in_layer_1).
Unfortunately count and sum is not supported by dbf driver, so it is necessary
to use postgres.
Radim
