I'm working on a chapter on the "region" for the GRASS tutorial and I have
a question concerning altering the default region. What arguments (other
than not wanting to have users play around in the GRASS database) are
there against creating a current region that is larger than the default
region and then replacing the DEFFAULT_WIND with the WIND file (or a named
region file) containing the parameters of that larger region ? Would any
of the existing maps suffer from this ?
Moritz
There isn't any reason why the default region shouldn't be changed.
It's arguable that g.region should have an option to update the
default region instead of the current one, although I don't know what
would be involved in implementing this.
