I am trying to add layers to a vector map with attributes managed with postgresql. My first attempt with v.db.addtable, created the correct tables in postgres. They appear to be attached to the vector map
GRASS 6.1.cvs (minnesota_utm):~ > v.info -c t61nr9w_tvol layer=1
Displaying column types/names for database connection of layer 1:
INTEGER|cat
INTEGER|a_cat
DOUBLE PRECISION|a_area
DOUBLE PRECISION|a_perimeter
DOUBLE PRECISION|a_pls_fort_
DOUBLE PRECISION|a_pls_fort_i
INTEGER|a_coun
INTEGER|a_town
INTEGER|a_rdir
INTEGER|a_rang
INTEGER|a_sect
INTEGER|a_fort
INTEGER|a_glot
INTEGER|a_parc
CHARACTER|a_fort_desc
DOUBLE PRECISION|a_glotmatch
INTEGER|b_cat
GRASS 6.1.cvs (minnesota_utm):~ > v.info -c t61nr9w_tvol layer=2
Displaying column types/names for database connection of layer 2:
INTEGER|cat
INTEGER|cords
INTEGER|mbm
INTEGER|poles
INTEGER|posts
This looks correct to me. However, v.category on both layers shows that when layer 2 is specified, v.category reports layer 1:
GRASS 6.1.cvs (minnesota_utm):~ > v.category input=t61nr9w_tvol option=report layer=1
LAYER/TABLE 1/t61nr9w_tvol:
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 686 1 686
area 0 0 0
all 686 1 686
GRASS 6.1.cvs (minnesota_utm):~ > v.category input=t61nr9w_tvol option=report layer=2
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 686 1 686
area 0 0 0
all 686 1 686
Also, when I try and view or edit the new layers with d.what.vect. There are no "tabs" showing all the layers. Did I miss a step when creating the layers?
Kirk
