[GRASS5] current release branch
On Fri, Oct 11, 2002 at 09:08:35PM +0100, Glynn Clements wrote:
Bernhard Reiter wrote:
> I agree that a common code style is important.
> My point was that automatic reformatting has to be followed
> by human inspection.
Why? indent understands enough of C not to change the semantics of the
code. Outside of string literals and preprocessor directives, all
whitespace is equal.
... I also think that the Apache programmers know what they do
(i.e. using indent, that's were I got that indent line from):
http://httpd.apache.org/dev/styleguide.html
We should learn from that project.
On Fri, Oct 11, 2002 at 09:35:15PM +0200, Bernhard Reiter wrote:
Otherwise we paralize development too much. At least this was feared.
... unfortunately (maybe not avoidable) that has already started:
we have
- NVIZ CVS version in 5.0
- upcoming contributions from Bob Covill (5.0, very welcome):
    - bugfixes
    - improvements
- NVIZ enhanced with 3D vectors in 5.1
As efforts have been recently started to integrate G3D into NVIZ, we should
be careful not to end up in a total mess. In my opinion we should hardly work
on the transition to 5.1.
On Sat, Oct 12, 2002 at 11:25:43AM +0500, Sharma Ojaswa wrote:
can't we use the kde development tools to port whole of the grass into a
good looking GUI( prepared by the gui tools available in linux)
KDE would mean C++ and all kde libs.
I'd rather go with a better cross platform application framework.
Thus the hottest candidate if I'd ever would approach this is wxPython.
This is not stopping development.
It is splitting it up.
No chance to avoid this and porting and backporting.
Yes, sure.
On the other hand, there probably going to be a 5.0.x
release from the current GRASS50 CVS HEAD.
(5.0.1 might come off the old release branch if Glynn can
convince me that we have bad _critical_ bugs in there.)
Also, there isn't a free version of Qt for Windows at present.
Unfortunately, wxWindows is also C++.
If the Windows version of GTK+ is adequate, I'd suggest using GTK+.
right. Thats why Bernhard proposed wxPython, the Python wrapper for
wxWindows. A language like Python works quite well for gluing
functionality together for a GUI.
I wrote a small wxPython sample for automatically building GUI dialogs
from the --interface-specification of GRASS commands some time ago.
I also tested this and it works. However, you'll have a GTK-looking
application under Windows which looks a bit alien.
The big advantage of wxWindows is the concept of using native frameworks
for GUI building. E.g. MSFC is used if the programm is executed on a
Windows platform, GTK (or even QT) is used if you are on a GNU/Linux
system. There is also a solution for MacOS.
  Jan
Jan-Oliver Wagner http://intevation.de/~jan/
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
True. WxPython wraps this in an okay way, though.
It seems that Microsofts libraries are mostly exposing C++ apis.
Thus there is no real way around c++ for Windows GUIs.
AFAIK it isn't.
Furthermore it is not an application framework.
