[GRASS5] curses, foiled again!
I've been trying to get Grass 5.3.0 to compile on a new SuSE 9.1 installation.
Most things are working well, however...
V_call.o in the vask library uses __waddbytes, which is defined in the curses
library, but not in the ncurses library. The config routine specifies
-lncurses for everything that uses libvask.a, but it doesn't specify
-lcurses, which leaves __waddbytes undefined.
I can go through the (long and tedious) labor of recompiling each of the
failed modules manually, but I would rather find and fix the problem. Where
and how would I look to fix this?
Roger Miller
In all probability, the vask code is using the headers from one
version of curses but the programs which use it are being linked
against a library from a different version, and the two aren't
compatible.
Many of the curses "functions" which vask uses are actually actually
implemented as macros. FWIW, V_call.c uses the following curses
symbols:
  curscr
  stdscr
  addch
  addstr
  getch
  getyx
  move
  refresh
  wrefresh
On my system, these result in the following curses dependencies in
V_call.o:
  curscr
  stdscr
  waddch
  waddnstr
  wgetch
  wmove
  wrefresh
with the missing symbols corresponding to the following macros:
#define addch(ch) waddch(stdscr,ch)
#define addstr(str) waddnstr(stdscr,str,-1)
#define getch() wgetch(stdscr)
#define getyx(win,y,x) (y = (win)?(win)->_cury:ERR, x = (win)?(win)->_curx:ERR)
#define move(y,x) wmove(stdscr,y,x)
#define refresh() wrefresh(stdscr)
Presumably your curses.h defines one of these macros (probably addstr)
in terms of __waddbytes().
Essentially, you need to determine suitable settings for the
--with-includes= and/or --with-libs= configure switches such that the
compiler and linker will use a matching set of headers and library.
Note that the vask source code always refers to <curses.h>, but the
linker will use either -lncurses or -lcurses, depending upon which one
configure detects first (i.e. it will only use -lcurses if the check
fails for -lncurses).
One option is to create a temporary directory containing a symlink
named curses.h which refers to the ncurses version of the header, and
specify that via the --with-includes= switch.
Another option is to manually edit either src/CMD/head/head.<arch> or
mk/vars.mk (depending upon which build system is being used) and
change CURSES to use -lcurses instead of -lncurses.
