I changed some group ownerships and permission in the CVSROOT repository
directory to add even more security.
Let me know if anybody is encountering unusual problems now.
Bernhard
Bernhard
Yes, the CVSROOT/history file must be 666.
I tried to commit changes to head/cygwin32 and it failed.
John Huddleston
----- Original Message -----
To: Grass Developers Mailinglist <grass5@geog.uni-hannover.de>
Sent: Tuesday, May 23, 2000 3:52 AM
Subject: [GRASS5] CVS administration
Let me know if anybody is encountering unusual problems now.Bernhard
subject 'unsubscribe grass5'
Hello Bernhard
Did this include making some files like src/CMD/lists/GRASS read only? We just
noticed this when we tried to change this file after we performed a cvs update.
Is this part of your change or is this a feature of cvs update?
Sincerely,
People who think they know everything are very irritating to those
of us who do. ---Anonymous
On Tue, May 23, 2000 at 05:09:16PM +0000, Justin Hickey wrote:
Hello Bernhard
Hi Justin,
I have the same problem with this file (and a few others).
Is it related to cvs watch or cvs edit (John, you will know it )
Thanks
No, the cvs update, watch, and edit commands do not
change permissions on the local directory.
Justin, chmod the directory to 777 locally. If the
repository directory were read only, then you would
not have been able to checkout a file. It needs to
do a temporary lock and lock directory for the
short period of time that you are accessing the file.
John Huddleston
From: Markus Neteler <neteler@geog.uni-hannover.de>
To: <grass5@geog.uni-hannover.de>
Sent: Tuesday, May 23, 2000 6:47 AM
Subject: Re: [GRASS5] CVS administration
> Hello Bernhard
We just
update.
Hi Justin,I have the same problem with this file (and a few others).
Is it related to cvs watch or cvs edit (John, you will know it)
Thanks
Upps. Sorry for that.
It should be remedied now.
Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Hello John
change permissions on the local directory.Justin, chmod the directory to 777 locally. If the
OK, so does this mean that there is something changing the permissions locally?
If so, do you think it is related to my local version of CVS somehow or should
I be looking somewhere else for the problem? Since Markus also reported the
same problem, I am tempted to think it has something to do with CVS, but I have
no idea how CVS could change the permissions especially with your comment
above.
Thank you for your help.
Sincerely,
Justin,
Can you remember the commands that you have typed recently?
Bernhard just changed the CVSROOT directory files and that
does not affect the grass files; they are in a different directory
structure.
John Huddleston
From: Justin Hickey <jhickey@impact1.hpcc.nectec.or.th>
Sent: Wednesday, May 24, 2000 3:27 AM
Hello John
locally?
should
the
have
above.Thank you for your help.
Sincerely,Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, ThailandPeople who think they know everything are very irritating to those
of us who do. ---AnonymousJazz and Trek Rule!!!
Hello John
Justin,Can you remember the commands that you have typed recently?
structure.
If I remember correctly, I ran a cvs update, then a cvs -d update a few days
later and then I tried to change the src/CMD/lists/GRASS file, and it turned
out to have read only permissions. Maybe I'm wrong, but I was sure I had write
access before, since I changed it before I compiled my checkout version. The
only thing I can think of is that I may be getting confused with the last time
I compiled the source from download (not CVS) which was only a few weeks before
I got my checkout version. Can someone check the permissions of this file in
the repository? Maybe that will clear things up if they are read only.
Thanks for your help.
Sincerely,
Hi Justin, (et al)
CVS files are stored at 444, or read-only in the repository. The
repository is setup this way so that no one can accidentally clobber
a file. The directories in the repository are either set up as 775
or 777 depending on how the administrator chooses to organize
permissions by groups or for all users respectively. This is
necessary since at checkout, a lock file and a lock directory
are written temporarily.
So, the permissions for your local directory are managed by you
with your 'umask' and other environment processes. Sometimes
backup procedures change permissions temporarily. Has there
been an OS change on your system? In any case, start at the
top and chmod the directories, e.g.
find . -type d -exec chmod 777 {} \;
John Huddleston
Sent: Friday, May 26, 2000 12:06 PM
Hello John
days
turned
write
The
time
before
in
Dear developers,
from the untested section of 4.x I have added some modules:
src/mapdev/
v.llabel - label all unlabeld vectors (see v.alabel)
v.rm.dangles - remove dangles
v.in.arc.poly - import ARC/INFO polys with closed polygons
v.out.mif - export MIF (working? Rich, for you?)
v.rmdup - remove duplicate vector lines # note: does not compile yet!
src/misc
m.in.ntf - module to read an Ordnance Survey NTF file
Except v.llabel they are not added to src/CMD/lists/GRASS yet.
Please tell me if they are compiling/working for you.
They might be useful for your work or developments.
Best regards
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
Hello John
top and chmod the directories, e.g.find . -type d -exec chmod 777 {} \;
Thank you for all your help and information. I already did the chmod on all
files. There was no operating system change that I know of. Anyway, it is not a
major problem and we'll see what happens on my next update.
Again, thank you for your time and help with this.
Sincerely,
