[GRASS5] CVS branch with latest 5.0 code?
Hi GRASS developers,
with all the CVS merging lately, I lost track somewhat -- which branch now
has the latest 5.0 code -- still "releasebranch_11_april_2001_5_0_0"? So, to
start fresh I'd do:
cvs co -r releasebranch_11_april_2001_5_0_0 grass
Right?
How do I check out GRASS 5.1 -- "cvs co grass5.1"?
Aleksey
start fresh I'd do:
Right?
The release branch should be almost identical to the head. If a file
exists in both the release branch and the head, both versions should
be identical. The head will also contain some files which don't exist
in the release branch (e.g. d.vect.area and r.mapcalc3).
It's called "grass51".
Thanks, Glenn.
Aleksey
> start fresh I'd do:
> Right?
