I'm planning on importing a new grass_doc module into the intevation repository pretty soon. I just have a cvs question:
in the cvs book it says that the syntax for imports is:
cvs import -m "msg" projname vendortag releasetag
What should I use for vendortag and releasetag ?
Moritz
hm, I am not sure which vendor tag was used for the other
grass modules, but basically it is not important what
you specify (perhaps "grass"?)
For releasetag you may use "start" IIRC.
Jan
Jan-Oliver Wagner http://intevation.de/~jan/
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
