[GRASS5] CVS read/write access down
In order to add some features to the cvs. The
read write access it down right now for maintainace.
You might get errors when trying.
I let you know when things are going better.
Sorry for the inconvenience.
  Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Read write CVS access should be alright again.
Markus: Where do you want a cvs-commit maillinglist?
Do you want to set it up at your site, where the grass-development list
is?
  Bernhard
Fine, thanks!
is?
Yes, why not. I can call it "grasscvs". We can discuss details
personally.
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
subject 'unsubscribe grass5'
length: 1467
max: 0
One recommendation on the CVS commits list:
Set the reply-to header on the message to the
grass development list. This makes it easier
to discuss any issues that might arise with a
particular commit.
Fine, thanks!
> is?
personally.
length: 1467
max: 0
| Eric B. Mitchell mailto:emitchell@altaira.com |
| tel: (301) 809 - 3534 Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122 Bowie, MD 20716 |
              ,___
          /"\ / o=\ /"""---===/
         / \_/ \__/ ---===/
         | //\ || /""TT""/ //\ || ||""\
         | // \ || || // \ || ||__/
         | //--==\ |L--/ || //--==\ || || "=,
           \____---===/
length: 2966
max: 0
particular commit.
Eric,
a good idea.
But: I do not know PERL enough...
It needs to be implemented to set the "reply_to"
with an configuration parameter in config file.
A few things can be set in minordomo, but not
reply_to. In case you could help, I will send
the minordomo.pl to you.
length: 1471
max: 0
> particular commit.
a good idea.
I took the liberty to switch it over on this end here.
Place the perl script into the CVSROOT directory
and we can all add to it.
John Huddleston
----- Original Message -----
From: Markus Neteler <neteler@geog.uni-hannover.de>
To: <grass5@geog.uni-hannover.de>
Sent: Wednesday, May 10, 2000 11:05 AM
Subject: Re: [GRASS5] CVS read/write access up again (was: [GRASS5] CVS
read/write access down)
> particular commit.
Eric,
a good idea.
length: 1471
max: 0
length: 2890
max: 0
Sorry.
the minidomo system seems to override it. :frowning:
  Bernhard
That would be o.k. with me of course, but:
Sorry. the minidomo system seems to override it. :frowning:
  Bernhard
I contacted the minordomo programmer. Maybe he is willing
to help.
length: 1466
max: 0
particular commit.
from the minordomo programmer I was told that
he will include the "reply_to" feature within the
next ours. Then above will be possible.
length: 1277
max: 0
