Hi GRASS Developers,
this mail is to inform you that I will
work on the CVS respository related tools today.
Two changes are planned so far:
- use intevation.de's hostkey even for the grass cvs ssh port
You will probably see the hostkey changed.
- Change the http browsing tool from
cvsweb
to
viewcvs
(it basically does the same.)
Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
It was not done. The same old ssh hostkey is still used.
cvsweb
to
viewcvs
Done. (This probably makes security problems less likely.)
Check: http://freegis.org/cgi-bin/viewcvs.cgi
Markus: The link to the current bugs file has to be:
Check: http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass/BUGS
Bernhard
