Hello,
While waiting for a new, consolidated d.vect: here is the new version of my d.area.class script for use with the latest d.vect.area version (see below for usage).
Linked to that a question I asked in another mail without getting a response (I guess is was buried in the rest) :
Is it possible to access the predefined palettes (greyscales, red to green, etc) from the shell ?
And if not, how are they implemented (i.e. how to create color scale dynamically depending on
the number of categories) ? A hint to the relevant places in the source code would be enough (I just don't want to reinvent the wheel).
Usage: d.area.class map=name catfile=name classes=boundary1[,boundary2,..] linecolor=R:G:B [colfile=name][reclass=name]
Parameters:
map = vector map to display
catfile = variable file with 2 columns seperated by whitespace: 1=category 2=variable by which to class
classes = class boundaries separated by comma (but no whitespaces), starting with boundary between class 1 and 2 and ending with boundary between class
max-1 and max
linecolor = color of boundary lines given in Red Green Blue values seperated by colons (default: 0:0:0=black)
colfile = name of the file into which you wish to save the color legend file
reclass = name of the file into which you wish to save the reclass rules
Moritz
(attachments)
darea~1.cla (3.96 KB)
