[GRASS5] d.extend won't work with vectors
I was looking at adding a button to the GIS Manager that would use d.extend to let people zoom to the maximum extent of all displayed maps. I tested it to make sure it worked as described and discovered that it works fine with rasters. However, with the new GRASS 6 vector format, d.extend will either generate an error or produce a region with an extent of 0 in one dimension (E-W so far)
Error example. I used the Spearfish data set. If I extract and display a subset of archsites (cat 2-6), then run d.extend, I get this error.
GRASS 6.1.cvs (spearfish57):~ > d.extend
ERROR: <nsres=0.000000> ** invalid input **
The region either won’t change to match the map extents or it will go to 0 in one dimension. I can’t consistently reproduce the error of actually setting the region to 0, but it has happened several times.
I guess I won’t add that button yet, but perhaps someone could look into this.
Thanks
Michael
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
