No big enhancements like adding support for symbols, but it now has
better error handling, debug info and will survive d.redraw if input was
given from a file. Added an updated version of grass.logo.sh from the
GRASS 5 source into the module's source dir as an example. Also added a
command to set the text rotation.
I didn't bother to do the same updates to d.mapgraph as I plan on
merging it into the d.graph module as the "-m" flag. In regards to that
effort, if anyone wants to merge the malloc -> G_malloc changes, please do!
How easy/hard would it be to add different line widths at some point?
Michael
Arizona State University
Tempe, AZ 85287-2402
Date: Wed, 14 Dec 2005 15:22:42 +1300
To: grass5 <grass5@grass.itc.it>
Subject: [GRASS5] d.graph updates
I've done a little cleanup on the d.graph module.
Easy & done.
Also added a -m flag to use geographic coordinates (the d.mapgraph merge).
TODO: (preferably by someone else)
a) merge in G_malloc() fixes from d.mapgraph, any other bug fixes?
After this is done we can add a
G_warning("Module superseded; use 'd.graph -m' instead");
to d.mapgraph. Perhaps it is preferable to remove d.mapgraph from CVS
and have init scripts set up `alias d.mapgraph='d.graph -m'` ?
b) update "icon" instruction to use GRASS 6 symbols. This requires
copying out the icon display code from d.vect and making a new display
lib routine. After that we would modify d.graph to use the new
D_symbol() fn.
-- do we want to call them symbols or icons? I find it confusing to use both.
Please read the updated help page. Pointed out a previously undocumented
feature (polyline) among other things.
It may be useful to run at DEBUG level = 3.
I think the module is pretty useful now. It will be even beter when the
icons are updated.
