(actually, this is probably addressed mostly to Hamish and perhaps Glynn, since their IDs are associated with the files in question, but I have self-doubts on my understanding of the CVS system and its logs...)
Is d.info incompletely added to the repository, or just a work in progress? I just tried to compile GRASS 5.7 from scratch and it stopped there looking for main()... upon examination I see there are no source files in there, so I've removed d.info from the parent makefile and am continuing.
I would just assume that I had caught the middle of an update, but apparently this directory was created two days ago...
Oops, same for r.in.mat (and out) - just the directory, no source code.
Apologies if this is a really common/normal issue.
Scott
Scott Mitchell, Assistant Professor, Carleton University
Department of Geography & Environmental Studies, Loeb A209
Mailing: Loeb B349, 1125 Colonel By Dr., Ottawa, ON K1S 5B6 Canada
1-613-520-2600 x2695 Fax: 613-520-4301 Scott_Mitchell@carleton.ca
and am continuing.
Yes they seem to be only partially added. You also need to copy over the
source code files from 5.3. The normal way to do this is add the lines
src/display/d.info/* display/d.info/*
src/raster/r.in.mat/* raster/r.in.mat/*
src/raster/r.out.mat/* raster/r.out.mat/*
to tools/link.conf in the 5.7 source tree, and then run make mix again
Perhaps I'll make a conjecture that Hamish didn't finish this because
nobody had decided if the new modules should go into 5.7?
and am continuing.
Scott
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
and am continuing.
It appears that Hamish forgot to update the tools/link.conf file.
> code.
Yeah, sorry about that folks. It should be ok now..
