I have changed default form mode for vector attributes in d.m to GUI,
you change to terminal output using 'g.gisenv set=DM_FORM_MODE=txt'.
Radim
Radim
There was a check box on the vector panel of the GIS Manager to switch to
terminal output. I hope it is still there for those of us for whom form mode
is broken.
Michael
you change to terminal output using 'g.gisenv set=DM_FORM_MODE=txt'.Radim
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
is broken.it is still there and it works. i however suggest to set this button to "1" by default to make the query tool button work out of the box on all systems.
It means that nobody will use that or even dicover that possibility and
nobody try to fix it.
Radim
regards
USAvoice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton_______________________________________________
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
I'm OK with setting it to 0 given Radim's reasons and the fact that it can
be also set in g.gisenv (and HOPE that someone can fix this).
form mode
systems.It means that nobody will use that or even dicover that possibility and
nobody try to fix it.Radim
regards
grass5 mailing list
grass5@grass.itc.it
C. Michael Barton, Professor of Anthropology
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
for the development version, that's very true!
> and nobody try to fix it.
perhaps look at it this way:
Binary packagers (e.g. on Mac where it is known to break), can apply
whatever patches within the GPL they feel makes for a better package.
[but please make a note somewhere and keep a diff handy]
The "official" CVS source shouldn't deal with bugs by sweeping them
under the carpet, otherwise they never get fixed.
This way general users get a working program and advanced users are
forced to notice it.
Hamish
