[GRASS5] d.mon select "ERROR eof from graphics driver."
I just did a 6.1-cvs update & rebuild on an Athlon. (Debian/stable)
I mistakenly used CFLAGS="-march=pentium4".
It gets past the configure step and the compile without errors.
The first error I find when I restart GRASS is when I go to start a
monitor:
G61> d.mon start=x0 -s
using default visual which is TrueColor
ncolors: 16777216
Graphics driver [x0] started
[window opens]
G61> d.mon sel=x0
[window closes]
G61 > d.mon start=x0
ncolors: 16777216
Problem selecting x0. Will try once more
Socket is already in use or not accepting connections.
Use d.mon to select a monitor
[window briefly opens then closes]
My beef is with the configure step; can we have a better test that
catches this sort of thing? Currently it doesn't mind:
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc -ggdb -march=pentium4 -Wall ) works... yes
checking whether the C compiler (gcc -ggdb -march=pentium4 -Wall ) is a cross-compiler... no
checking whether we are using GNU C... yes
I guess as configure only tests that a snippet compiles, not that it
actually runs (to allow cross-compiler functionality), we should
leave things as-is?
Anyway a hint for anyone searching the archives for this error..
Hamish
