[GRASS5] d.rast behavior
Glynn wrote:
Actually, it erases the entire window (frame), not just any raster
maps which were displayed within it.
I think that is correct behavior unless -o is specified, though I think
the documentation could be a little more clear on that point.
The only reason which springs to mind is that the user might wish to
retain something which is displayed in the portion of the frame which
isn't overwritten, e.g. a legend. I've occasionally used an extreme
aspect ratio to ensure that d.rast *didn't* overwrite a legend.
As it stands, the user can have either behaviour; "d.rast ..." alone
just draws the raster, "d.erase ; d.rast ..." clears the window and
draws the raster.
It worked originally as "d.rast ..." erased the window and drew the
raster and "d.rast -o ..." just drew the raster. You get the same
behavior either way, except that with -o you get the added feature that
null values are transparent.
Also, if the behaviour is so desirable when run without "-o", why not
when run with "-o"? Of course, getting it right for "-o" is much
harder to implement, but that doesn't mean that the issue ceases to
exist.
I don't recall that there was any real problem with the way it worked
originally.
A related issue is whether "-o" should be the default behaviour, with
e.g. "-n" for "fill null cells". The existing behaviour is largely an
artifact of the lack of a distinct no-data value in 4.x, where only
the user knew if zero was zero or no-data.
I'm fine with the flags as they were. Displaying a raster without -o
always obscures any vector or raster already displayed and I don't think
there's a way around that. It makes sense to me that the default
behavior should be for d.rast to clear the display, and that there
should be an overlay option (-o) to specify that the existing display
content is not deleted and that null-valued cells are transparent.
I do think we need to go one way or the other on this now and to fix the
documentation accordingly.
Roger
