here I post new version with patch from Martin.
We have one problem:
if one uses "for line in `echo "SELECT...."|db.select`
and if db.select returns more words from the dabase, each string is handeld as
separate variable $line
nlines=0;
new_cat=0;
# searching for categories
for line in `echo "SELECT $GIS_OPT_column,GRASSRGB FROM $table ORDER BY grassrgb"|db.select -c fs=";"`;
do
eval `echo "$line"|sed -e s/^/cat=\"/|sed -e s/\;/\"\;\ color=\"/|sed -e s/$/\"/`
# is this new category?
for index in `seq 1 $nlines`; do
cur_cat=${cat_vals[$index]}
#echo "#$cat# #$cur_cat#"
if [ "$cur_cat" == "$cat" ]; then
new_cat=1;
fi
done
# if it is new category, add to arrays cat_vals and cat_clrs
if [ "$new_cat" == "0" ]; then
index=`expr $index + 1`;
cat_vals[$index]="$cat";
cat_clrs[$index]="$color";
nlines=`expr $nlines + 1`;
new_cat=0;
fi
#echo $nlines # if you use 'echo "SELECT ..."|while read line' here it is OK
done
#echo $nlines # but here it gots value from line no 125
we tryed to implement something like
echo "SELECT $GIS_OPT_column...."|db.execute| while read line; do
done
hoewer the $nlines variable gets its original value (=0)
any idea ?
Jachym
On Tue, May 17, 2005 at 08:09:24AM -0700, Michael Barton wrote:
tatus: RO
Content-Length: 828
Lines: 35
I'll take a look at it.
On 5/17/05 2:50 AM, "Jachym Cepicky" <jachym.cepicky@centrum.cz> wrote:
> Hallo developers,
> before I rewrite d.legend so it is able to work with vector maps too (and I'm
> still not sure, if I ever get it), i wrote a script, based on d.vect.thematic,
> which should solve as d.vect.leg. It does the same, as d.rast.leg does too.
> The
> difference from d.vect.thematic is, that this script works with GRASSRGB
> column
> from the database.
> Anyone for testing?
> Screenshot at http://les-ejk.cz/.../d.vect.leg.png
> Jáchym
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
(attachments)
d.vect.leg (4.07 KB)
