[GRASS5] d.vect.line question
I was trying to create a legend file for a vector file and ran into a problem that others must have encountered before. Hopefully someone can offer a solution.
My vector contour map has negative numbers. That is, it measures depth below surface (not unusual for archaeologists). However, -1 in a legend file has a special meaning of 'all the rest of the lines'. In fact, it seems that it is treating all my negative numbers in that way.
How can I use a legend file to specify colors of vectors with negative attributes? Or is this impossible?
Thanks
Michael Barton
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
I have not given a look to the code so I suggest only a "trick": map
negative attributes to positive ones ( for example "shifting" the
0 comparison plan to, say, 65536, translate att -> 65536 + att).
Thierry Laronde (Alceste) <tlaronde@polynum.org>
Key fingerprint = 0FF7 E906 FBAF FE95 FD89 250D 52B1 AE95 6006 F40C
