[GRASS5] d.vect.thematic committed to CVS
I fixed a few small bugs and committed d.vect.thematic and v.univar.sh to the CVS.
Items fixed in this submission:
support (I hope) for non-dbf tables
support for international numeric notation (“,” vs “.” for decimals)
recognition of odd (i.e., not even) medians and 2nd quartile
Thanks for all your help. Now those of you with nifty ideas for further enhancement can go at it.
Michael
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
to the CVS.
both:
- to "activate" new modules, you need to add them to the parent
Makefile, e.g. grass6/scripts/Makefile.
- Instead of a table= option, parse the output of v.db.connect -g (or -p)
to get the answer automatically. I see you have commented out in thematic:
#v.db.connect map=fields2 -pg
note -pg isn't correct, choose one or the other. If this doesn't show
the correct table then it is a bug & should be fixed.
v.univar.sh:
please keep option names consistent with other modules, e.g. 'db.connect
driver= database=' instead of drv= and db=.
d.vect.thematic:
get rid of "#% key: icon" options line. Why restrict?
G> ls $GISBASE/etc/symbol/*
colorscheme=
I'm a huge fan of blue->cyan->yellow->red. Why not let it be any of the
colorschemes in $GISBASE/etc/colors/? (ok, very hard to parse in a shell
script)
if [ "$OPT_GIS_table" = "" ] ; then
use instead: (probably breaks on cygwin)
if [ -z "$OPT_GIS_table" ] ; then
min="`grep 'Minimum:' TMP1 | sed s/Minimum://`"
max="`grep 'Maximum:' TMP1 | sed s/Maximum://`"
mean="`grep 'Mean:' TMP1 | sed s/Mean://`"
etc.
change TMP1 -> "$TMP1"
Always try to "quote" file names. (spaces in names, etc)
themecolor=$color1":"$color2":"$color3
to
themecolor="$color1:$color2:$color3"
(not a big deal, just cleaner)
.. and that's about as far as I got through an audit.
nice work,
Hamish
Hamish
Thanks much for all the suggestions for a cleaner script. A couple replies
below, but will try to change these tomorrow if I have a few minutes.
to the CVS.
both:
Oops. I was in a hurry to commit them because people were starting to modify
various versions floating around.
Db.select will automatically use the values already set in db.connect, so we
don't need to check this (at least I don't think we do). Previously I had it
default to dbf (a problem). Now it defaults to whatever is already set
unless it is specifically set to something else in the script.
v.univar.sh:
OK. I was trying to avoid confusion with the db.select arguments. But
consistency is nice.
d.vect.thematic:
Because I don't know how to parse this into a g.parser-style interface. This
is indeed a bit of a hack.
I'm working on a way to do this however.
colorscheme=
script)
Also working on this. It is a bit complicated to do in a way that remains
user-friendly.
OK
etc.
Quotes inside quotes?? TMP1 is a file, not a variable. I copied this out of
r.univar.sh. Are you sure about this? I'll give it a try.
to
OK
Thanks much.
nice work,
Hamish
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
Hi Michael
v.univar.sh:
d.vect.thematic:
Why not an icon in GIS Manager?
Select the vector map in the list and press the thematic icon. It have to extract the vector name automatically.
Other future option:
- thematic mapping for TEXT values. Unique values
Great work Michael
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti@bologna.enea.it ||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/ || | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
Fixed in CVS this morning. See below for details.
USA
Date: Fri, 13 May 2005 15:04:55 +1200
To: Michael Barton <michael.barton@asu.edu>
Cc: <grass5@grass.itc.it>
Subject: Re: [GRASS5] d.vect.thematic committed to CVS
to the CVS.
both:
Fixed
Not needed given how v.univar.sh is done now
v.univar.sh:
d.vect.thematic:
No change for now. Working on a more sophisticated way to do this.
colorscheme=
script)
Fixed
etc.
This doesn't work with "$TMP1". Kept TMP1.
to
Fixed
Also fixed 'legend' output to make it more readable.
nice work,
Hamish
> d.vect.thematic:
> etc.
You are creating a file called "TMP1" in the current directory,
v.univar.sh -e table=$GIS_OPT_table column=$GIS_OPT_column > TMP1
should be
v.univar.sh -e table=$GIS_OPT_table column=$GIS_OPT_column > "$TMP1"
then the rest should work too.
Hamish
> etc.
out of r.univar.sh. Are you sure about this? I'll give it a try.
you are correct, no need for quotes inside quotes.
The missing $ stands though.
Hamish
