[GRASS5] d.vect.thematic wish: handle null values
Trying to make maps with d.vect.thematic I have stumbled upon the problem that
the module fails when there are null values in the table (postgresql):
awk: (FILENAME=- FNR=1) fatal: division by zero attempted
Thematic map legend for column revmed of map ssbxl01
Value range: - 33079
Mapped by 7 intervals of
Color(R:G:B) Value
0:0:250 7 -
DBMI-Postgres driver error:
Cannot select:
SELECT cat FROM ssbxl01 WHERE revmed >= 7 and revmed<=
ERREUR: L'opérateur n'existe pas : integer <=
HINT: Aucun opérateur correspond au nom donné et aux types d'arguments. Vous
devez ajouter des conversions explicites de type.
35:0:215 -
Cannot select:
SELECT cat FROM ssbxl01 WHERE revmed > and revmed<=
ERREUR: syntax error sur ou près de «and» at character 41
etc...
Now I can see two theoretical solutions to this:
1) handle null values
2) allow to give a value that represents null values (e.g. -99999)
For both of these solutions, d.vect.thematic should offer the choice of a
color for these values, so that they do not use the same color scheme as the
'valid' values.
Moritz
I'm not sure that nulls are the problem. It won't accept the <= operator.
Try straight > and < and see what happens. Also, what is FNR=1?
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
From: Moritz Lennert <mlennert@club.worldonline.be>
Reply-To: <mlennert@club.worldonline.be>
Date: Thu, 11 Aug 2005 23:20:00 +0200 (CEST)
To: Grass Developers List <grass5@grass.itc.it>
Cc: <michael.barton@asu.edu>, <dcalvelo@minag.gob.pe>
Subject: d.vect.thematic wish: handle null values
Color(R:G:B) Value
0:0:250 7 -
Cannot select:
35:0:215 -
Cannot select:
etc...
'valid' values.
Moritz
The operators are not defined by me but by d.vect.thematic.
The problem is not the <= operator, but the fact that in the sql statement
there should be an integer after the <=.
This integer is missing because the awk script tries to divide by zero because
of the null values.
(FNR is an internal awk variable which stands for the "input record number in
the current input file")
I can confirm that it is the null values that are the problem since if I
replace them with any integer value (0, -99999, etc) d.vect.thematic runs
perfectly, but it creates the classes including the null-replacing integer
since it doesn't know that they are special values, and there is no way of
telling it this.
This is why I plead for one of the two solutions below...
Hope this helps clarifying the issue.
All the best,
Moritz
Michael
USA
that
Color(R:G:B) Value
0:0:250 7 -
Cannot select:
Vous
35:0:215 -
Cannot select:
etc...
'valid' values.
Moritz
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Thanks for the clarification Moritz. Is this in the custom breaks section?
This was written by Daniel Calvelo. I'm copying him in case he has any
ideas.
Michael
USA
Date: Fri, 12 Aug 2005 00:53:33 +0200 (CEST)
To: Michael Barton <michael.barton@asu.edu>
Cc: Grass Developers List <grass5@grass.itc.it>, <dcalvelo@minag.gob.pe>
Subject: Re: [GRASS5] Re: d.vect.thematic wish: handle null values
of the null values.
telling it this.
All the best,
Moritz
Michael
USA
that
Color(R:G:B) Value
0:0:250 7 -
Cannot select:
Vous
35:0:215 -
Cannot select:
etc...
'valid' values.
Moritz
grass5 mailing list
grass5@grass.itc.it
No, this happens independently of the 'themecalc' choice.
ideas.
He already was in the cc-list, so he got your last message twice :wink:
Moritz
Sorry, I lied: actually the custom breaks are the only ones that work...
All the others fail, with more or less the same error message...
Moritz
Moritz,
In that case, it's in v.univar.sh. I'm not sure how to treat the null value
issue. It's an awk thing. They should be excluded from calculations and not
treated as 0's
Michael
USA
Date: Fri, 12 Aug 2005 11:27:32 +0200 (CEST)
Cc: "daniel.calvelo@minag.gob.pe" <daniel.calvelo@minag.gob.pe>, Grass
ideas.
Moritz
Then this is definitely in v.univar.sh
Michael
USA
Date: Fri, 12 Aug 2005 11:42:51 +0200 (CEST)
Cc: Michael Barton <michael.barton@asu.edu>, "daniel.calvelo@minag.gob.pe"
<daniel.calvelo@minag.gob.pe>, Grass Developers List <grass5@grass.itc.it>
Moritz
I think that this is the place in v.univar.sh that needs to be updated to
deal with null values
# calculate statistics
echo "Calculating statistics..."
cat $TMP | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0}
NR == 1{min = $1 ; max = $1}
       {sum += $1 ; sum2 += $1 * $1 ; N++}
        if ($1 > max) {max = $1}
        if ($1 < min) {min = $1}
END{
print ""
print "Number of values:",N
print "Minimum:",min
print "Maximum:",max
print "Range:",max-min
print "-----"
print "Mean:",sum/N
print "Variance:",(sum2 - sum*sum/N)/N
print "Standard deviation:",sqrt((sum2 - sum*sum/N)/N)
print "Coefficient of variation:",(sqrt((sum2 -
sum*sum/N)/N))/(sqrt(sum*sum)/N)
print "-----"
I think there needs to be the equivalent of
for $1<>""
in the beginning of this. Any awk expert know how to implement this?
Of course if v.univar were expanded to accomplish the same things as
v.univar.sh ...
Michael
Moritz
Sorry for jumping in so late, I've been traveling.
AFAIR the problem is actually within db.select's output. Moritz, could you
apply this patch to v.univar.sh and send the result (in /tmp/db.select.out)
back to me? When I was dealing with this problem I only used the DBF driver,
which gave zeros for nulls under unspecified cirsumstances.
I can fix the script to filter out nulls, but I'm pretty sure the problem will
remain under certain configurations.
-- Daniel Calvelo Aros
---------- Original Message -----------
To: mlennert@club.worldonline.be
Sent: Sat, 13 Aug 2005 17:12:29 -0700
updated to deal with null values
END{
print ""
print "-----"
print "Mean:",sum/N
print "-----"
for $1<>""
v.univar.sh ...
Michael
> Moritz
grass5 mailing list
grass5@grass.itc.it
------- End of Original Message -------
(attachments)
aa.patch (365 Bytes)
On Mon, August 15, 2005 20:50, Daniel Calvelo said:
back to me?
done off-list.
Thinking about this a bit more this seems more like a bug to me. Making nulls
into zeroes gives very different results than if nulls are excluded from the
calculations.
At the user should be warned about this.
As I mentioned earlier, we have to think a about whether it is better to
silently exclude nulls, or whether we should explicitely give the opportunity
to exclude a certain value (or range or values) from the classification. This
would then allow those with nulls in their files to transform them to any
value (e.g. -99999) and exclude it from the calculations.
Maybe above solution is more generic. But in any case nulls should be handled
more gracefully...or at least a warning included in the man page...
Moritz
From: "Moritz Lennert" <mlennert@club.worldonline.be>
Sent: Sun, 28 Aug 2005 11:53:34 +0200 (CEST)
Making nulls into zeroes gives very different results than if nulls
are excluded from the calculations.
better to silently exclude nulls, or whether we should explicitely
give the opportunity to exclude a certain value (or range or values)
from the classification. This would then allow those with nulls in
their files to transform them to any value (e.g. -99999) and exclude
> problem will
be handled more gracefully...or at least a warning included in the
man page...
I fixed CVS to *ignore* nulls.
I'd say that is a good choice for use in d.vect.thematic. If you really really
want to use a symbol/color for NULL values, there is always the possibility of
overlaying d.vect.thematic with a d.vect where="the_field is null".
Furthermore, current db.execute allows for things like 'update table set
field=cat+23 where field is null', which allows to take care of any case I can
think of, either inserting new fields and marking them appropriately or
modifying existing fields in-place.
Daniel.
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
problem will
man page...
Great, now it works for me. Thanks !
I agree.
BTW: I just committed a slight addition to the legend drawing
routine for drawing black lines around the legend boxes. Just
thought it looks nicer that way...now if only these legends could be
exported in a more usable form...(will commit a wish for this just
for memory)
Moritz
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDFF4srIrMbm76jD8RAstWAJ9MM6l3oLGxBfLYQNxtwUMw5Pj4agCeKPbO
lOXYOACxZdQwlciec5Z2rsY=
=nS1Z
-----END PGP SIGNATURE-----
Moritz,
This is great.
Michael
USA
Date: Tue, 30 Aug 2005 15:25:00 +0200
To: Daniel Calvelo <daniel.calvelo@minag.gob.pe>
Cc: <grass5@grass.itc.it>, <michael.barton@asu.edu>
Hash: SHA1
problem will
man page...
really
of
can
I agree.
for memory)
Moritz
=nS1Z
