On Sun, 27 Feb 2005, Markus Neteler wrote:
On Sun, Feb 27, 2005 at 05:19:50PM -0500, Helena wrote:
> Markus,
> is elev the result of v.surf.rst (or s.surf.rst)?
> If yes, this seems to be rst problem - Susane Rizzolli has already reported
> it.
Ah, didn't know that. Yes, it's v.surf.rst from current CVS.
Thanks for your quick reply.
> If you multiply the result by 1.0 in r.mapcalc, the quant is recomputed
> and the result of query is correct.
> rst calls quantize here - I did not have time to look at what quantize
> actually does and why are the min and max values done like this,
> rst was updated for FP support while FP support was still under development
> so quant might have changed and this is now producing wrong result.
> G_quantize_fp_map_range (params->elev, mapset,
> (DCELL) zminac - 0.5, (DCELL) zmaxac + 0.5,
> (CELL) (zminac - 0.5), (CELL) (zmaxac + 0.5));
> It might have been there for years, but nobody is probably using the quant
> result, so there were no compliants
Would be nice to get it fixed. Maybe Glynn with his insights has
a suggestion?
There is code in src/rastput.c (after line 160) and R/rast.put.R (after
line 39) in the R GRASS package that puts quantization in place for layers
being written to GRASS. The default is to use about 20 "pretty" intervals,
but other schemes can be imposed by the user. I seem to remember that
setting it up was not as simple as I had expected. Getting the colours and
interval labels right seemed to matter - since nobody has complained since
2003, I guess it isn't too badly broken (on 5.4).
Roger
> Helena
> >Hi,
> >looking at d.what.rast, I see output like this:
> >d.what.rast
> >Buttons
> > Left: what's here
> > Right: quit
> >278786.03515625(E) 5232741.95078125(N)
> >elev in PERMANENT, quant (447)
> >elev in PERMANENT, actual (447.190521)
> >279031.25390625(E) 5233060.73515625(N)
> >elev in 5(E) 5232741.95078125(N)
> >elev in PERMANENT, quant (539)
> >elev in PERMANENT, actual (540.034363)
> >278700.20859375(E) 5235660.05390625(N)
> >elev in PERMANENT, quant (-557)
> >elev in PERMANENT, actual (-558.007324)
> >The quantization rule is not obvious to me, what's the
> >background to get such results?
> >Thanks
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand@nhh.no
