[GRASS5] Darwin Pre1 gtty stty errors
On Monday, June 4, 2001, at 06:21 PM, Glynn Clements wrote:
So should I try and replace the calls myself, or would someone be
willing to help? An ideal simple test module that has this problem it
d.colors.
The current implementation of d.colors uses the TCGETA/TCSETAW
ioctl()s if HAVE_TERMIO_H is defined and stty()/gtty() otherwise. If
you're getting errors regarding stty() or gtty(), then it appears that
configure hasn't detected the <termio.h> header.
Hello Glynn,
Hmm, I have two instances of "termios.h", one in /usr/include/termios.h and /usr/include/sys/termios.h, however I cannot locate a file with the name "termio.h" anywhere on my system.
However, the ioctl()s themselves have been superseded by the POSIX.1
tcgetattr() and tcsetattr() functions.
A more significant "however" is that d.colors/tty.c is redundant; the
only functions which are used are Get_old_tty() and Get_new_tty().
These store the terminal settings before and after curses
initialisation. But the stored settings are never used, i.e. neither
Old_tty() nor New_tty() are called.
I will commit a fix which removes this code, which should eliminate
any portability considerations altogether. If you know of any other
programs which do this, let me know.
I greatly appreciate the information, and better yet a fix!
The following 3 modules in addition to d.colors fails for the same reason:
   i.points
   i.points3
   i.vpoints
Please let me know when I may update the module(s) and give it a whirl.
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
