On Sunday, October 14, 2001, at 12:41 AM, Glynn Clements wrote:
Can you please let me know when I can check it out?
It's ready; if I say "about to commit", it will probably be done
within a few minutes of the email being sent.
Hello,
Thanks Glynn, for graciously pointing that out to me.
Will I have to re-build everything and start out with a "make
distclean", or will I be able to just run configure and then build the
PNGDriver?It should suffice to run configure then build PNGdriver.
Thank you! I checked-out all of the config files and ran configure again and it was apparently successful:
checking whether to use PNG... yes
checking for location of PNG includes...
checking for png.h... yes
checking for location of PNG library...
checking for png_read_image in -lpng... yes
checking whether to use GD... yes
checking for location of GD includes...
checking for gd.h... yes
checking for location of GD library...
checking for gdImagePng in -lgd... no
checking for gdImagePng in -lgd... yes
checking for gdImagePng in -lgd... (cached) yes
checking for gdImageGif in -lgd... no
Built then when I go to build the PNGDriver I run into trouble with undefined symbols:
gcc -o /usr/src/grass/dist.powerpc-apple-darwin1.4/driver/PNG OBJ.powerpc-apple-darwin1.4/Can_do.o OBJ.powerpc-apple-darwin1.4/Color.o OBJ.powerpc-apple-darwin1.4/Draw_line.o OBJ.powerpc-apple-
darwin1.4/Get_w_box.o OBJ.powerpc-apple-darwin1.4/Get_w_line.o OBJ.powerpc-apple-darwin1.4/Get_w_pnt.o OBJ.powerpc-apple-
darwin1.4/Graph_Clse.o OBJ.powerpc-apple-darwin1.4/Graph_Set.o OBJ.powerpc-apple-darwin1.4/Panel.o OBJ.powerpc-apple-
darwin1.4/Polygn_abs.o OBJ.powerpc-apple-darwin1.4/Reset_clr.o /usr/src/grass/src/display/devices/lib/LIB.powerpc-apple-
darwin1.4/driverlib.a /usr/src/grass/src/libes/LIB.powerpc-apple-
darwin1.4/libgis.a -lz -L/usr/local/pgsql -L/usr/local/lib
/usr/bin/ld: Undefined symbols:
_gdImageLine
_gdImageDestroy
_gdImagePng
_gdImageColorAllocate
_gdImageColorTransparent
_gdImageCreate
_gdImageFilledPolygon
_gdImageColorClosest
make: *** [/usr/src/grass/dist.powerpc-apple-darwin1.4/driver/PNG] Error 1
Now, I grep'ed for gdImagePng and gdImageLine:
[localhost:/usr/src/grass] root# grep gdImagePng /usr/local/include/*
/usr/local/include/gd.h:void gdImagePng(gdImagePtr im, FILE *out);
/usr/local/include/gd.h:void gdImagePngCtx(gdImagePtr im, gdIOCtx *out);
/usr/local/include/gd.h:void gdImagePngToSink(gdImagePtr im, gdSinkPtr out);
/usr/local/include/gd.h:void* gdImagePngPtr(gdImagePtr im, int *size);
[localhost:/usr/src/grass] root# grep gdImageLine src/display/devices/PNGdriver/*
src/display/devices/PNGdriver/Draw_line.c: gdImageLine(im, cur_x, cur_y, x, y, currentColor);
And it seems like something is adding the underscores to the symbols, messing things up. Unfortunately, I have no idea why.
Can anyone offer a hint?
BTW: What does the PNGDriver do? Is it optional?
Jeshua Lacock http://OpenOSX.com
Programmer/Owner http://SierraMaps.com
Phone: (760) 935-4736 http://3dTopoMaps.com
