Greetings all,
There is just 1 standard module that fails to compile now, r.fill.dir on Darwin. Amazing, my first build of beta 8 had 27 failed modules! : )
It appears to me a limitation of the math.h file installed with Darwin.
MAXDOUBLE is not defined, however there there is a MAXFLOAT defined. Would it be safe to assign the same vaule to MAXDOUBLE?
Additionally, MINFLOAT and MINDOUBLE have not been defined. Is there a value that I could assign them?
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
Hi Jeshua
Darwin.
Since the math library is not part of the standard C library I would
suggest that these constants be changed to those in float.h which is
part of the standard library.
Namely, DBL_MAX, DBL_MIN, FLT_MAX, and FLT_MIN would probably be better
choices.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
On Mon, Jun 11, 2001 at 10:26:10AM +0700, Justin Hickey wrote:
Hi Jeshua
> Darwin.
I don't think you meant to say that (maybe "those constants
are not a part of the ISO standard C math library" ?).
choices.
Eric G. Miller <egm2@jps.net>
Hi Eric
constants are not a part of the ISO standard C math
library" ?).
Oops, you're right. Will you accept "It's Monday morning" as an excuse?
Sincerely,
Bangkok, Thailand
