[GRASS5] db.connect and auto-creation of dbf/ directory
when using db.connect to define in a new mapset the DB connection,
I face following non-feature:
db.connect driver=dbf database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
db.connect -p
driver:dbf
database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
schema:(null)
group:(null)
So far so nice. But:
g.copy vect=ammprv,pat_ammprv
COPY [ammprv@PERMANENT] to current mapset as [pat_ammprv]
DBMI-DBF driver error:
Cannot open dbf database: /ssi0/ssi/neteler/grassdata/pat/export/dbf/
WARNING: Cannot open database '/ssi0/ssi/neteler/grassdata/pat/export/dbf/'
no database is open
WARNING: Cannot copy table
WARNING: Cannot copy ammprv@PERMANENT to current mapset as pat_ammprv
Yes, I know, that the user has to create this directory first. But
this could also be done by the program.
So, where to apply a code modification:
- db.connect - when using dbf driver?
- g.copy/g.rename - when using dbf driver ?
Markus Neteler wrote:
db.connect -p
driver:dbf
schema:(null)
group:(null)
no database is open
The directory is created automatically if no driver/databvase is defined and a vector module has to write a new table.
If a user takes the responsability to define the database, he must also create it.
Nowhere, I believe.
Radim
I'd vote for g.copy. You need to have the dbf directory in existence for
some modules to put something into. That is, you need it before there is
anything IN it to connect with.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Date: Thu, 21 Apr 2005 15:27:20 +0200
To: grass5 developers list <grass5@grass.itc.it>
Subject: [GRASS5] db.connect and auto-creation of dbf/ directory
db.connect -p
driver:dbf
schema:(null)
group:(null)
no database is open
Excuse me, I don't understand your vote. You vote for leaving
this as-is? In the direction of Radim's comment?
> From: Markus Neteler <neteler@itc.it>
> Hi,
> db.connect -p
> driver:dbf
> schema:(null)
> group:(null)
> no database is open
> Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
> > database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/' db.connect -p
> > driver:dbf
> > schema:(null)
> > group:(null)
> > '/ssi0/ssi/neteler/grassdata/pat/export/dbf/' no database is open
> > pat_ammprv
Just to point out where this bites me: v.in.garmin creates a new vector
file with 'v.in.ascii type=standard'. It then makes a table with
db.execute:
v.in.ascii format=standard output="$NAME" input="${TMP}.dig"
echo "CREATE TABLE $NAME ($ATTR_COLS)" | db.execute
if its a new mapset with e.g., no dbf/ or VAR, you get this error:
ERROR: No db connection for driver <(null)> defined. Run db.connect
Understandable, but still not very nice for the end-user who just wants
it to be created automatically if it doesn't exist. Maybe db.execute is
a "raw" command so people using it must do so at their own
responsibility. 'v.in.ascii format=points' does create DB link/folder if
needed automatically, which is nice.
If I add in DB checking logic to v.in.garmin before trying to create a
table does it make everyone happy or does an issue still remain?
ie should
make sure that '$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/' exists for the
driver=dbf case, as it will just mean a mkdir?
I still don't understand how db.connect sees database='$MAPSET' without
`eval g.gisenv` ... internal?
Hamish
