Because the id field is an integer it doesn't require single quotes:
echo "INSERT INTO laender ( id, cat ) VALUES(86, 'YY')"|db.execute
Yours,
Forrest R. Stevens
-----Original Message-----
From: grass5-admin@grass.itc.it [mailto:grass5-admin@grass.itc.it] On
Behalf Of Stephan Holl
Sent: Thursday, January 27, 2005 9:11 AM
To: grass5@grass.itc.it
Subject: [GRASS5] db.execute
Dear List,
I have problems to insert new rows in a newly created attribute-table.
my given command:
echo "INSERT INTO laender ( id, cat ) VALUES('86', 'YY')"|db.execute
DBMI-DBF driver error:
Incompatible value type.
Error in db_execute_immediate()
ERROR: Error while executing: "INSERT INTO laender ( id, cat )
VALUES('86', 'YY')
But I have no success, the dbf-attribute-table stays empty.
The table:
db.describe laender
table:laender
description:
insert:yes
delete:yes
ncols:2
