[GRASS5] db.xxx v.db.xxx question
dear all,
i am trying to connect several databases to a vector-layer (DBF-database).
here's the scenario: there are point-vectors (sites), which have a cat-value
and an additional integer value X.
There's also a huge DBF database ("B") with additional content for the
point-vectors.
Linking the additional database with v.db.connect to the vector is no
problem (as layer 2), but how is the key-value set correctly ?
The original database uses the CAT-value as the key-value and apparently
there is no way to fiddle with this.
Hooking up database "B", the column X_ID (holds the same values as column X
in the original vector-database) is declared as _key_.
What is lacking is the referencing of the keys:
Let's say, the CAT-values range from 1 to 10, while the X-values are
distributed at random between 1000 - 2000.
It would be great if a mouse-based-query to "site 1" [CAT == 1, X == 42]
would select the correct row in database B [where X_ID == 42, Type == "great
place"].
How can this be done ?
Peter
Dr. Peter Löwe
Diplom-Geograph
<loewe@geomancers.net>
<peter.loewe@gmx.de>
+++ NEU: GMX DSL_Flatrate! Schon ab 14,99 EUR/Monat! +++
GMX Garantie: Surfen ohne Tempo-Limit! http://www.gmx.net/de/go/dsl
