(sorry if you received this twice, Markus Neteler recommended me to send it here too)
I work on ODBC (http://www.unixodbc.org/) driver for DBMI (src/libes/dbmi)
+ some modules based on DBMI.
Work is not finished but most of old modules (src/libes/dbmi/clients) and new
v.db.reclass run.
I want discuss following list of changes before commiting to CVS:
- add to src/include/dbmi.h structures:
typedef struct _db_connection
char *driverName;
char *databaseName;
char *location;
char *user;
char *password;
char *keycol; // name of default key column
}dbConnection;
typedef struct
int count; // number of defined rules
int alloc; // size of allocated array
char *table; // table name
char *key; // key column name
int *cat; // array of new category numbers
char **where; // array of SQL WHERE conditions
char **label; // array of new category labels
}dbRclsRule;
- add to DBMILIB functions:
int db_set_connection (dbConnection *connection );
int db_get_connection (dbConnection *connection );
void db_rcls_rule_extend (dbRclsRule *rule , int n );
dbRclsRule * db_rcls_rule_init (int n );
int db_rcls (dbRclsRule *rule , CatValI **new );
- add to /src/libes/dbmi/lib/start.c reading from dbConnection if driver
was not specified
- modify command parameters in src/libes/dbmi/clients modules
to not required if defined in dbConnection (use default)
- change in src/libes/dbmi/clients/Gmakefile:
HOME=$(GISBASE)/etc/dbmi/bin
to
HOME=$(GISBASE)/etc/bin/main/cmd
and remove
if [ ! -d $(GISBASE)/etc/dbmi ]; then mkdir $(GISBASE)/etc/dbmi; fi; \
if [ ! -d $(HOME) ]; then mkdir $(HOME); fi;
- add src/libes/dbmi/drivers/odbc - ODBC driver
- add src/libes/dbmi/clients/db.connect - similar as g.select.pg but
module name db.select is already used, problem: password is saved
in file
- add src/mapdev/v.db.reclass
- add to VECTLIB_REAL functions for reclassification - may be used in future also
by v.reclass (I am not satisfied with creating reclass file and running
v.reclass
from DB reclass modules):
int V_rcls_line (char *in_name, char *out_name, CatValI *new, int ncat, int
append);
int V_rcls_area (char *in_name, char *out_name, CatValI *new, int ncat, int
append, int dissolve);
- add to src/include/gis.h structures for storing values for cats
( new category value, number of elements in cat, area, length, x,y, ...)
typedef struct
int min,max; // array range
int *val; // array of integers
}CatValI;
typedef struct
double *val; // array of doubles
}CatValD;
- add to GISLIB functions:
CatValI *G_catvali_init( int min, int max);
void G_catvali_extend( CatValI *, int max);
Radim
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
subject 'unsubscribe grass5'
length: 3835
max: 0
