[GRASS5] [DebianGIS-dev] Bug#336498: grass: broken macro LOC_CHECK_VERSION (also FTBFS on GNU/FreeBSD)
Fwd from the Debian Bug Tracker--
Begin forwarded message:
Date: Sun, 30 Oct 2005 20:14:39 +0100 (CET)
To: submit@bugs.debian.org
Subject: [DebianGIS-dev] Bug#336498: grass: broken macro LOC_CHECK_VERSION (also FTBFS on GNU/FreeBSD)
Package: grass
Severity: important
Please split macro LOC_CHECK_VERSION from aclocal
into LOC_CHECK_VERSION_STRING and LOC_CHECK_VERSION_NUMBER
and use them appropriate in configure.in.
Current version check is unreliable.
Generated snippet, i.e.:
#include "confdefs.h"
#include <stdio.h>
#include <proj_api.h>
int main(void) {
FILE *fp = fopen("conftestdata","w");
char *p;
p = PJ_VERSION;
fputs(p, fp);
return 0;
is compiled OK, only with "warning: assignment makes pointer from integer
without a cast".
When the created binary is executed, random (given by arbitrary version
integer) memory is accessed and result might be either segfault or garbage from memory.
It currently segfault on GNU/Linux => package can be compiled
and returns garbage on GNU/FreeBSD => it FTBFS there.
It would be nice if you could get fixed it into upstream.
Temporarily the attached patch can be also used.
Thanks in advance,
        Petr
--- grass-6.0.1.orig/configure
+++ grass-6.0.1/configure
@@ -6421,31 +6421,6 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
else
   cat > conftest.$ac_ext <<EOF
-#line 6425 "configure"
-#include "confdefs.h"
-#include <stdio.h>
-#include <proj_api.h>
-int main(void) {
- FILE *fp = fopen("conftestdata","w");
- fputs(PJ_VERSION, fp);
- return 0;
-EOF
-if { (eval echo configure:6437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
-then
- proj_ver=`cat conftestdata`
- echo "$ac_t""$proj_ver" 1>&6
-else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -fr conftest*
- if test "$cross_compiling" = yes; then
- proj_ver=UNKNOWN
- echo "$ac_t""unknown (cross-compiling)" 1>&6
-else
- cat > conftest.$ac_ext <<EOF
#line 6450 "configure"
@@ -6471,11 +6446,6 @@
rm -fr conftest*
fi
-fi
-rm -fr conftest*
-fi
CPPFLAGS=$ac_save_cppflags
Pkg-grass-devel mailing list
Pkg-grass-devel@lists.alioth.debian.org
http://lists.alioth.debian.org/mailman/listinfo/pkg-grass-devel
Does anyone know how to modify 'configure.in' for this problem?
Thanks
Package: grass
Severity: important
#include <stdio.h>
int main(void) {
char *p;
p = PJ_VERSION;
fputs(p, fp);
return 0;
without a cast".
Thanks in advance,
       Petr
else
-#include <stdio.h>
-int main(void) {
- return 0;
-EOF
-then
-else
- rm -fr conftest*
- proj_ver=UNKNOWN
-else
rm -fr conftest*
fi
-fi
-rm -fr conftest*
-fi
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
LOC_CHECK_VERSION does 2 tests. First it tries to compile this program:
#include <stdio.h>
int main(void) {
return 0;
Since PJ_VERSION is defined to be 449 or some similar number this will
produce a compiler warning. -Werror will make gcc act as if warning are
errors ==> compilation fails and this is never run. The macro then tries
to build this program:
#include <stdio.h>
#include <$1>
int main(void) {
fprintf(fp, "%d", $2);
return 0;
which will compile in this case, and write the version to the
conftestdata file.
So to fix this all you need to do is introduce the -Werror flag to the
gcc commandline, which is trivial to do. All you need to do is modify
configure.in line 516. Add -Werror to the 5th parameter of the macro call.
Your line should now look something like this: (without linebreaks).
LOC_CHECK_VERSION(proj_api.h,PJ_VERSION,
    External PROJ.4,proj_ver,$PROJINC -Werror,UNKNOWN)
I don't have a BSD to test on so I can't say if this works or not, but
on GNU/Linux PowerPC it does work.
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
I've committed the following changes:
1. In aclocal.m4, replace LOC_CHECK_VERSION with:
AC_DEFUN(LOC_CHECK_VERSION_STRING,[
AC_MSG_CHECKING($3 version)
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$5 $CPPFLAGS"
AC_TRY_RUN([
#include <stdio.h>
#include <$1>
int main(void) {
fputs($2, fp);
return 0;
[ $4=`cat conftestdata`
    AC_MSG_RESULT($$4)],
[ AC_MSG_ERROR([*** Could not determine $3 version.]) ],
[ $4=$6
    AC_MSG_RESULT([unknown (cross-compiling)]) ])
AC_DEFUN(LOC_CHECK_VERSION_INT,[
AC_TRY_RUN([
#include <stdio.h>
#include <$1>
int main(void) {
return 0;
    [ $4=$6
2. In configure.in:
a) replace:
  LOC_CHECK_VERSION(proj_api.h,PJ_VERSION,External PROJ.4,proj_ver,$PROJINC,UNKNOWN)
with:
  LOC_CHECK_VERSION_INT(proj_api.h,PJ_VERSION,External PROJ.4,proj_ver,$PROJINC,0)
b) replace:
  LOC_CHECK_VERSION(tcl.h,TCL_VERSION,Tcl,tcl_ver,$TCLINCDIR,UNKNOWN)
with:
  LOC_CHECK_VERSION_STRING(tcl.h,TCL_VERSION,Tcl,tcl_ver,$TCLINCDIR,UNKNOWN)
c) replace:
  LOC_CHECK_VERSION(tk.h,TK_VERSION,Tk,tk_ver,$TCLINCDIR $X_CFLAGS,UNKNOWN)
with:
  LOC_CHECK_VERSION_STRING(tk.h,TK_VERSION,Tk,tk_ver,$TCLINCDIR $X_CFLAGS,UNKNOWN)
