hi,
we discovered that two subsequent full compilation
runs lead to a significant recompilation. We would
expect that nearly nothing is recompiled in the second
run. This seems to be a new "feature" - any ideas
where to look for that?
hi,
I've committed this fix to CVS:
Index: include/Make/Rules.make
RCS file: /grassrepository/grass6/include/Make/Rules.make,v
retrieving revision 1.31
diff -u -r1.31 Rules.make
--- include/Make/Rules.make 4 Nov 2005 08:35:06 -0000 1.31
+++ include/Make/Rules.make 10 Mar 2006 00:37:26 -0000
@@ -14,7 +14,7 @@
NLS_CFLAGS=$(GETHOSTNAME) $(ZLIBINCPATH) $(PICFLAGS) $(DEFS)
# default cc rules
-$(OBJDIR)/%.o : %.c $(DEPENDENCIES) $(LOCAL_HEADERS)
+$(OBJDIR)/%.o : %.c $(LOCAL_HEADERS)
@test -d $(OBJDIR) || mkdir $(OBJDIR)
$(CC) $(CFLAGS) $(EXTRA_CFLAGS) $(NLS_CFLAGS) $(EXTRA_INC) $(INC) \
-o $(OBJDIR)/$*.o -c $*.c
$(DEPENDENCIES) is the list of *libraries* on which an executable
depends.
Because libgis is rebuilt each time, anything which lists a dependency
upon $(GISDEP) (i.e. almost everything) will be re-compiled from
scratch.
The fact that libgis is rebuilt each time means that modules still
have to be re-linked, but that should be a lot quicker than
re-compiling.
The reason that libgis is rebuilt each time is that version.h is
re-installed (to dist.<arch>/include/grass) on each run, gisinit.o has
a dependency upon version.h, and libgis has a dependency upon
gisinit.o.
To eliminate the re-linking, I've committed this:
Index: lib/gis/Makefile
RCS file: /grassrepository/grass6/lib/gis/Makefile,v
retrieving revision 1.43
diff -u -r1.43 Makefile
--- lib/gis/Makefile 7 Feb 2006 13:15:57 -0000 1.43
+++ lib/gis/Makefile 10 Mar 2006 01:07:49 -0000
@@ -10,8 +10,7 @@
EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
endif
-default: $(ARCH_INCDIR)/version.h \
- lib \
+default: lib \
$(FMODE_OBJ) \
$(ETC)/ellipse.table \
$(ETC)/datum.table \
@@ -27,9 +26,6 @@
echo -e "#include <stdlib.h>\n#include <fcntl.h>\n#undef _fmode\nint _fmode = _O_BINARY;" > $(OBJDIR)/fmode.c
$(CC) $(CFLAGS) $(INC) -o $(FMODE_OBJ) -c $(OBJDIR)/fmode.c
-$(ARCH_INCDIR)/version.h:
- echo 'static char *GRASS_VERSION_STRING = "@(#) GRASS $(GRASS_VERSION_NUMBER) ($(GRASS_VERSION_DATE))";' > $@
$(ETC)/ellipse.table: ellipse.table
rm -f $@
$(INSTALL) -m 644 $? $@
@@ -113,7 +109,6 @@
$(OBJDIR)/get_row.o: G.h
$(OBJDIR)/get_window.o: G.h
$(OBJDIR)/gisinit.o: G.h
-$(OBJDIR)/gisinit.o: $(ARCH_INCDIR)/version.h
$(OBJDIR)/maskfd.o: G.h
$(OBJDIR)/opencell.o: G.h
$(OBJDIR)/put_row.o: G.h
The actual fix is simply the removal of the dependency at the bottom.
The first two parts are removed because they are redundant; the
configure script generates include/version.h, and the "headers" rule
in include/Makefile installs it in $(ARCH_INCDIR).
There are still a few modules which are re-linked:
1. XDRIVER, due to winname.h being updated on each run.
2. The various mod* programs from r.support, because they are *moved*
to $(ETC) rather than installed.
3. tools/timer, because the target is $(PGM) but the rule creates
$(ETC)/$(PGM), so $(PGM) will never exist.
I'll fix those shortly.
