[GRASS5] Deprecated code
Hello all developers
Some files have been found that appear to be deprecated, and as such we
have recently started to mark files and code as deprecated for deletion
for Grass 5.1. Basically, we are inserting a comment with the "mark"
***DEPRECATED***
in files that are deemed to be deprecated or similarily for portions of
code as well.
If you know of any files or code that is deprecated, then please insert
this "mark" appropriately. We can then easily remove all deprecated code
from the CVS tree before the release of Grass 5.1.
Example: For a file that is deprecated
Simply insert a comment at the top of the file like
  /* ***DEPRECATED*** */
Example: For a code snippet
Insert a comment above the deprecated code clearly describing what part
of the code is deprecated
  /* Function G_some_name() ***DEPRECATED*** remove for 5.1 */
  /* ***DEPRECATED*** code remove next 5 lines for 5.1 */
  /* Start ***DEPRECATED*** code */
  <some lines of code>
  /* End ***DEPRECATED*** code */
For actual code examples already in the CVS tree see the files
src/libes/gis/openvect.c and src/libes/gis/Gmakefile
Thank you for your time and if we make this small change, then we can
clean up a lot of code.
Thanks to David Gray for making this suggestion.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
subject 'unsubscribe grass5'
