To Grass5 list,
Concerning the linear algebra routines, can we use the
netlib http://www.netlib.org/master/expanded_liblist.html
work for grass?
John Huddleston, P.E.
USDA Computer Engineer
2150 Centre Ave, Bldg. A, T220
Fort Collins, CO 80526
(970) 295-5485 (Work)
(970) 295-5414 (FAX)
John.Huddleston@usda.gov
"Huddleston, John" wrote:
To Grass5 list,
work for grass?
In the long term, it would be good to have standard math libs for
modules to link to. For linear algebra, the BLAS etc. routines are as
standard as you get, and are also well tested and efficient. Only the
fact that they are mostly in fortran is felt by some to be a sticky
issue. I think though it is a significant project to go through all the
routines and change the calls to a central library.
For the current problem I am looking at the KVERT routine (or a C
translation of it) to just add to the module.
David
subject 'unsubscribe grass5'
