Is there any particular reason that the directed graph library headers
exist in both include/dgl and include/grass/dgl? Can one of these be
removed?
Brad Douglas <rez@touchofmadness.com> KB8UYR
Address: 37.49,-121.92 / WGS84 National Map Corps #TNMC-3785
GRASS GIS Developer
This applies to all header files. We decided to move all GRASS
header files to include/grass so that they can be installed on system
(e.g. in /usr/local/include) without conflicts.
Modules and especially independent applications using GRASS libraries
(GDAL/OGR, QGIS) should include grass/xxx.h instead of xxx.h.
At the moment we need both copies.
Radim
removed?
GRASS GIS Developer
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
I've committed a change to use <grass/xxx.h> throughout.
Nice! Thanks Glynn!
Thanks, however include/xxx.h is still used in QGIS and GDAL,
can you reenable the copy in include until those packagges are fixed?
Radim
If you add a symlink, e.g.
ln -s grass /usr/local/grass6/include/grass/grass
you can just specify /usr/local/grass6/include/grass as the GRASS
includes directory.
includes directory.
I can, but I am not sure if it is viable also for making packages,
debian e.g.?
Radim
> includes directory.
debian e.g.?
Are you asking about how to get the symlink into the package, or
something else? I'm not familiar with .deb packages, but if it's
essentially an archive (e.g. RPMs are just "wrapped" cpio archives),
it should be able to contain symlinks.
A copy should be unnecessary, and probably a bad idea, as you could
potentially end up with different versions in include and
include/grass (even if this is only a remote possibility, it's the
kind of problem where you could waste several days figuring out what's
wrong).
Hello Glynn,
On Mon, 13 Feb 2006 15:50:27 +0000 Glynn Clements
wrong).
Ahh, just finished an email to the list, where I ran in exacly the same
problem...
Therefor I would suggest to keep symlinks in include/*.h pointing to
include/grass*.h to have a backward-compatibility for other packages
which try to link against GRASS (e.g. QGIS, gdal-grass, etc.)
Could this be done easily?
Best
Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
> wrong).
problem...
Multiple symlinks are unnecessary. A single symlink and referring
configure to include/grass should suffice. See my other reply.
