[GRASS5] display system
the display system still is not working correctly.
I have locally updated to redraw the text with re-sizing of the monitor,
but if i create different frames on the display, then resize the
monitor, the screen is blank, nothing is re-drawn.
The frames are obviously added to the pad, as d.save -a works, but
something is broken with the redrawing part.
Any hints where to look? Is this a problem of the XDRIVER part?
I think that it is a real bug, so it should be fixed.
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
If you run the script generated by "d.frame -a", do you get the right
result? If so, the problem is with XDRIVER, otherwise it's with one or
more of the commands.
Actually, I suspect the former; XDRIVER only looks at the
"full_screen" pad.
I'm wondering if it would be better for XDRIVER to just run
"d.save -a", then have the redraw process run the resulting script.
"full_screen" pad.
I've committed a fix which appears to work.
In the process, I had to change Dnew(), as the existing behaviour
caused the frames to shrink slightly with each resize.
Answer: no. Doing that results in "d.save -a" waiting to connect to
the driver, which won't happen because the driver is waiting for
"d.save -a" to finish.
