Hello everyone,
Can anyone explain me how I can dissolve polygons, based on attributes, when
the boundaries are not adjacent.
Ricardo
DISCLAIMER: This message may contain confidential information or privileged material and is intended only for the individual(s) named. If you are not a named addressee and mistakenly received this message you should not copy or otherwise disseminate it: please delete this e-mail from your system and notify the sender immediately. E-mail transmissions are not guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete or contain viruses. Therefore, the sender does not accept liability for any errors or omissions in the contents of this message that arise as a result of e-mail transmissions. Please request a hard copy version if verification is required. Critical Software.
first you have to use r.reclass based on one column attribute to apply
attribute values to category values...
than you can use v.extract -d
later you have to reconnect database table to vector
hope this help....
ivan
Il giorno ven, 17-06-2005 alle 09:54 +0100, Ricardo Armas ha scritto:
Hello everyone,
attributes, when the boundaries are not adjacent.
Ricardo
you should not copy or otherwise dissemenate it: please delete this
late or incomplete, or contain viruses. Therefore, the sender does not
a hard-copy version if verification is required. Critical Software.
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini@unipg.it
ivan.marchesini@gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
