[GRASS5] doc translation
After consideration of comments on grass5, this is what I suggest for translation.
This could be grass_doc structure :
grass_doc
|-- oldsrc <- Doesn't change
`-- src
     |-- en <- Main directory for documentation (doesn't change)
     | `-- tutorial <- tutorial (xml files)
     |-- fr <- Directory for french translation
     | |-- messages <- Directory for french PO files
     | | `-- tutorial
     |-- ru <- other language, same stucture than french.
     `-- template <- POT files directory
         `-- tutorial
Encoding in "en" and "template" directory will be ISO-8859-1. Each other "translation team will use its own encoding.
I will use utf-8 for French translation and I encourage other to choose the same.
Jean-Denis
Jean-Denis Giguere said:
translation.
grass_doc
`-- src
     | | `-- tutorial
         `-- tutorial
the same.
Suits me, in the hope that all systems can deal with utf-8.
Moritz
