[GRASS5] Documentation question
  I've downloaded html_grass5.tar.gz and unravelled it into a directory.
When I look at grass_commandlist.html, I read the title as:
  GRASS 4.0 Command list reference
    (needs updating...)
and I wonder why it is in the GRASS5 documents, not updated.
  Has anyone put together a modified list representing the latest and
greatest version 5 commands?
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
              Making environmentally-responsible mining happen. (SM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
subject 'unsubscribe grass5'
    (needs updating...)
The answer is simple: Nobody updated it yet.
This should be done by a script as the "descriptions" are in most
commands now (Jan, will you add the missing G_descriptions?).
#--------------- script --------------------
cd $GISBASE/bin
for f in ?.*; do echo '---> '$f; $f -help; done 2>&1
Something to grep the "Description" needs to be added here.
Then we feed it into a html page. Probably above "-help" should
be replaced by "--interface-description" to get the XML output.
Just my 0.02 Euro
