[GRASS5] Draft GRASS 5.1 documentation available now
Ciao Roberto and Radim,
GRASS developers,
the last days I have started to implement GRASS 5.1 documentation
using doxygen. It is pretty easy :slight_smile: And we can generate
- HTML,
- Latex,
- PDF
(- XML, RTF etc)
from the GRASS source. Basic idea is to add some commands into the
source code which are then interpreted by 'doxygen'. An example:
\fn int db_fetch (dbCursor *cursor, int position, int *more)
\brief fetches something from somewhere
\return 0 on success, -1 on error
\param dbCursor, position in table, somethingelse
int
  C code of function;
(note the exclamation mark above which is needed)
See for real world examples:
grass51/lib/vector/Vlib/*
grass51/lib/db/dbmi/* [only placeholders added]
Overview pages can be easily written, see for example:
grass51/lib/vector/vector_arch.dox
which is now the "GRASS 5.1 Architecture" start page.
The major advantages are
- documenting in the source code (keeps things in sync)
- no extra programmer's manual to write and update
- possibility to auto-generate PDF manual by cronjob
- doxygen is a maintained project (http://www.doxygen.org)
To try GRASS-51-doc generation at home, enter (after updating from CVS):
cd grass51/lib/vector/
Now following commands are available:
- Generate HTML document:
        make htmldocs
- Generate Latex-DVI document (requires Latex):
        make latexdocs
- Generate PDF document (requires Latex):
        make pdfdocs
- Delete ./latex and ./html docs directories:
        make cleandocs
Let me kindly invite everybody to use and extend the GRASS documentation.
Roberto, you may also use it for DGLib...
For advanced tricks (Latex formula etc) see the doxygen site.
A today's PDF version is here:
http://mpa.itc.it/markus/tmp/grass51_2002_10_18refman.pdf
(520kb, please don't print as it will change)
A today's HTML version is here:
http://mpa.itc.it/markus/tmp/html/
Of course everything can be nicer, but it is a starting point.
an updated version of the draft GRASS 5.1 programmer's manual
is available now here:
http://mpa.itc.it/markus/grass51/index.html
A new "modules" section is added which organizes the
Vect_*() functions by topic (open functions, close functions,
network functions etc).
To improve the function detection, I need some regex assistance for
'sed' (compare
grass51/lib/vector/Vlib/generate_dox.sh
). In general I grep all '\\fn' from all *.c files, then I want
to extract the function names:
So, how can I extract words starting with 'Vect_' and ending with either
space or '('? The current solution in above script is not error free.
Examples:
\fn int Vect_tin_get_z( struct Map_info *Map
    -> Vect_tin_get_z
or
\fn struct line_cats *Vect_new_cats_struct ()
    -> Vect_new_cats_struct
etc. Unfortunately I don't know REGEX enough to write a 'sed' instruction.
GRASS developers,
- HTML,
- Latex,
- PDF
(- XML, RTF etc)
int
  C code of function;
        make htmldocs
        make latexdocs
        make pdfdocs
        make cleandocs
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
'sed' (compare
space or '('?
It's normally better to specify which characters *are* part of the
name rather than those which aren't. E.g.
  Vect_[a-zA-Z0-9_]*
Examples:
    -> Vect_tin_get_z
or
Try e.g.:
/^ *\\fn .*\(Vect_[a-zA-Z0-9_]*\).*$/s//\1/p
> 'sed' (compare
> space or '('?
  Vect_[a-zA-Z0-9_]*
that's of course better.
> Examples:
> -> Vect_tin_get_z
> or
Try e.g.:
Works perfectly. I have submitted to CVS.
