[GRASS5] EPSG update to GRASS?
please take the time to look at
http://bugzilla.remotesensing.org/show_bug.cgi?id=510
Frank updated EPSG files in PROJ and GDAL in CVS. I
assume that we should do the same to maintain synchronization.
If there are no objections, I'll update the two files
as indicated in above bug report.
On Wed, Apr 26, 2006 at 09:56:32AM +0200, Markus Neteler wrote:
OK, I didn't see objections.
So I have updated
lib/proj/
gcs.csv
pcs.csv
stateplane.csv
in CVS using the recently updated files from GDAL (gdal/data/)
which were also updated in PROJ4 (proj/nad/).
Since new GDAL and PROJ releases are expected very soon, there
shouldn't be any packaging issues.
PS: the related GDAL changlog entries:
2006-04-21 06:30 fwarmerdam
        * gcs.csv, pcs.csv: updated overrides
2006-04-21 06:01 fwarmerdam
        * gcs.csv, pcs.csv: updated with show_crs and deprecated columns
2006-04-08 01:26 fwarmerdam
        * stateplane.csv: Fixed California VII to point to fixed EPSG code.
2006-02-28 06:44 fwarmerdam
        * ellipsoid.csv, gcs.csv, gdal_datum.csv, pcs.csv,
          projop_wparm.csv, unit_of_measure.csv: upgrade to EPSG 6.9
The related PROJ entries:
2006-04-21 06:35 fwarmerdam
        * epsg: upgraded epsg lookup file
2006-03-10 14:30 fwarmerdam
        * epsg: updated to EPSG 6.9
Hello Markus,
On Thu, 27 Apr 2006 17:35:27 +0200 Markus Neteler <neteler@itc.it>
> Hi,
So I have updated
lib/proj/
gcs.csv
pcs.csv
stateplane.csv
for backward-compatibility could you tag (or somewhere promote the
cvs-commit-date of this update in CVS) so that we
know where to stop updating at least the proj-files to not run in
trouble when still using proj 4.4.9 and gdal 1.3.1?
Thanks
  Stephan
