[GRASS5] erase mon
grass57
when no monitor is started then pressing the "erase monitor" button in d.m
gives an error:
child process exited abnormally
    while executing
"exec -- d.erase white >@ stdout 2>@ stderr"
    ("eval" body line 1)
    invoked from within
"eval exec -- $cmd $args >@ stdout 2>@ stderr"
    (procedure "run" line 2)
    invoked from within
"run $cmd "
    (procedure "Dm::erase" line 4)
    invoked from within
"Dm::erase"
    ("uplevel" body line 1)
    invoked from within
"uplevel \#0 $cmd"
    (procedure "Button::_release" line 18)
    invoked from within
"Button::_release .mainframe.topf.tb0.bbox1.b3"
    (command bound to event)
Maciek Sieczka wrote:
grass57
gives an error:
    while executing
Well, it probably should give an error. However, the execute function
should probably install its own error handler rather than allowing
errors to go to the default Tcl error handler.
