[GRASS5] Error compiling g57
Dear Developers,
Error compiling g57:
the v.kernel module doesn't compile. I downloaded and compiled this
morning
from CVS.
Otto
###### error message #########
make[2]: Wechsel in das Verzeichnis Verzeichnis
»/home/dassau/software/grass57/vector/v.kernel«
gcc -I/home/dassau/software/grass57/include
-I/home/dassau/software/grass57/dist.i686-pc-linux-gnu/include -g -Wall
-Wall -Wconversion -Wno-implicit-int -I/usr/local/include
-DUSE_GDAL_H
-I/usr/local/pgsql/include -I/home/dassau/software/grass57/include
-I/home/dassau/software/grass57/dist.i686-pc-linux-gnu/include \
        -o OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c: In function `main':
main.c:213: parse error before `double'
main.c:218: `n' undeclared (first use in this function)
main.c:218: (Each undeclared identifier is reported only once
main.c:218: for each function it appears in.)
main.c:219: `resL' undeclared (first use in this function)
main.c:220: `sigmaConv' undeclared (first use in this function)
main.c:222: `ii' undeclared (first use in this function)
main.c:223: `smooth' undeclared (first use in this function)
main.c:239: `L' undeclared (first use in this function)
main.c:51: warning: unused variable `gausmax'
main.c:43: warning: unused variable `term2'
main.c:42: warning: unused variable `term1'
main.c:37: warning: unused variable `E'
main.c:37: warning: unused variable `N'
main.c:36: warning: unused variable `gaussian'
main.c:34: warning: unused variable `col'
main.c:34: warning: unused variable `row'
main.c:252: warning: control reaches end of non-void function
main.c: At top level:
main.c:254: `sigma' undeclared here (not in a function)
main.c:254: initializer element is not constant
main.c:254: warning: data definition has no type or storage class
main.c:255: `sigma' undeclared here (not in a function)
main.c:255: initializer element is not constant
main.c:255: warning: data definition has no type or storage class
main.c:257: `sigma' undeclared here (not in a function)
main.c:257: initializer element is not constant
main.c:257: warning: data definition has no type or storage class
main.c:259: parse error before `if'
main.c:266: conflicting types for `Points'
main.c:261: previous declaration of `Points'
main.c:266: warning: initialization makes integer from pointer without a
cast
main.c:266: initializer element is not constant
main.c:266: warning: data definition has no type or storage class
main.c:267: conflicting types for `SPoints'
main.c:261: previous declaration of `SPoints'
main.c:267: warning: initialization makes integer from pointer without a
cast
main.c:267: initializer element is not constant
main.c:267: warning: data definition has no type or storage class
main.c:268: conflicting types for `SCats'
main.c:262: previous declaration of `SCats'
main.c:268: warning: initialization makes integer from pointer without a
cast
main.c:268: initializer element is not constant
main.c:268: warning: data definition has no type or storage class
main.c:270: `Net' undeclared here (not in a function)
main.c:270: initializer element is not constant
main.c:270: warning: data definition has no type or storage class
main.c:271: parse error before `3'
main.c:271: warning: data definition has no type or storage class
main.c:277: `Net' undeclared here (not in a function)
main.c:277: `line' undeclared here (not in a function)
main.c:277: warning: passing arg 2 of `Vect_read_line' makes pointer
from
integer without a cast
main.c:277: initializer element is not constant
main.c:277: warning: data definition has no type or storage class
main.c:278: parse error before `if'
main.c:280: conflicting types for `length'
main.c:275: previous declaration of `length'
main.c:280: warning: passing arg 1 of `Vect_line_length' makes pointer
from
main.c:280: initializer element is not constant
main.c:280: warning: data definition has no type or storage class
main.c:281: `segmax' undeclared here (not in a function)
main.c:281: warning: data definition has no type or storage class
main.c:282: redefinition of `length'
main.c:280: `length' previously defined here
main.c:282: initializer element is not constant
main.c:282: warning: data definition has no type or storage class
main.c:284: parse error before `3'
main.c:284: warning: data definition has no type or storage class
main.c:289: `seg' undeclared here (not in a function)
main.c:289: initializer element is not constant
main.c:289: warning: data definition has no type or storage class
main.c:290: parse error before `&'
main.c:292: parse error before `3'
main.c:292: warning: data definition has no type or storage class
main.c:294: parse error before `&'
main.c:294: conflicting types for `compute_net_distance'
global.h:18: previous declaration of `compute_net_distance'
main.c:294: warning: data definition has no type or storage class
main.c:295: parse error before `*='
main.c:298: parse error before `3'
main.c:298: warning: data definition has no type or storage class
main.c:303: `seg' undeclared here (not in a function)
main.c:303: initializer element is not constant
main.c:303: warning: data definition has no type or storage class
main.c:304: warning: parameter names (without types) in function
declaration
main.c:304: warning: data definition has no type or storage class
main.c:306: warning: parameter names (without types) in function
declaration
main.c:306: warning: data definition has no type or storage class
main.c:307: parse error before `1'
main.c:309: parse error before `&'
main.c:309: conflicting types for `Vect_write_line'
/home/dassau/software/grass57/include/Vect.h:158: previous declaration
of
`Vect_write_line'
main.c:309: warning: data definition has no type or storage class
main.c:314: parse error before `&'
main.c:314: warning: data definition has no type or storage class
main.c:316: parse error before `&'
main.c:316: warning: data definition has no type or storage class
main.c:317: parse error before `&'
main.c:317: warning: data definition has no type or storage class
main.c:336: `row' undeclared here (not in a function)
main.c:336: `window' undeclared here (not in a function)
main.c:336: initializer element is not constant
main.c:336: warning: data definition has no type or storage class
main.c:337: `col' undeclared here (not in a function)
main.c:337: `window' undeclared here (not in a function)
main.c:337: initializer element is not constant
main.c:337: warning: data definition has no type or storage class
main.c:339: parse error before `&'
main.c:339: conflicting types for `compute_distance'
global.h:16: previous declaration of `compute_distance'
main.c:339: warning: data definition has no type or storage class
main.c:340: `col' undeclared here (not in a function)
main.c:340: variable `output_cell' has initializer but incomplete type
main.c:340: `multip' undeclared here (not in a function)
main.c:340: `gaussian' undeclared here (not in a function)
main.c:340: warning: data definition has no type or storage class
main.c:341: parse error before `if'
main.c:343: parse error before `2'
main.c:343: warning: data definition has no type or storage class
main.c:346: warning: parameter names (without types) in function
declaration
main.c:346: warning: data definition has no type or storage class
main.c:347: parse error before `}'
main.c:349: parse error before string constant
main.c:349: warning: data definition has no type or storage class
main.c:351: parse error before `&'
main.c:351: warning: data definition has no type or storage class
main.c:353: parse error before `0'
main.c:353: conflicting types for `exit'
/usr/include/stdlib.h:577: previous declaration of `exit'
main.c:353: warning: data definition has no type or storage class
main.c: In function `read_points':
main.c:368: warning: passing arg 1 of `calloc' as unsigned due to
prototype
main.c: In function `compute_all_distances':
main.c:396: warning: passing arg 1 of `calloc' as unsigned due to
prototype
main.c: In function `compute_all_net_distances':
main.c:433: warning: passing arg 1 of `calloc' as unsigned due to
prototype
main.c:489: conflicting types for `compute_net_distance'
main.c:294: previous declaration of `compute_net_distance'
main.c:539: conflicting types for `compute_distance'
main.c:339: previous declaration of `compute_distance'
make[2]: *** [OBJ.i686-pc-linux-gnu/main.o] Fehler 1
make[2]: Verlassen des Verzeichnisses Verzeichnis
make[1]: *** [subdirs] Fehler 1
make[1]: Verlassen des Verzeichnisses Verzeichnis
»/home/dassau/software/grass57/vector«
make: *** [default] Fehler 1
Yes,
we have found that as well, v.kernel does not compile with gcc2.*.
Stefano Menegon, original author of v.kernel, promised to solve this
until tomorrow (Italian tomorrow).
I'l remove v.kernel from vector/Makefile for now, do the same in your local copy.
Radim
On Thursday 29 January 2004 11:13, Otto Dassau wrote:
Dear Developers,
morning
from CVS.
Otto
-DUSE_GDAL_H
cast
cast
cast
from
from
declaration
declaration
of
`Vect_write_line'
declaration
prototype
prototype
prototype
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Is there some time frame of when grass 5.3 and 5.7 will be available for Windows 2000.
I have Cygwin installed on my machine but am not very good at using it so I thought I might wait for the Binaries to become available.
If someone has a lot of patience I could try out the Cygwin compile and install though...
My interest is in the use of GDAL and especially Shape files with the route analysis module in GRASS combined with Mapserver to display the results.
thanks,
Stephen
