[GRASS5] Error in fresh compile (ipc)
Hello all
I just did a fresh compile on our SGI system and had three errors.
1. r.cn - missing LDFLAGS in command line - fixed
2. r.in.gdal - same as always
3. The following messages at the end of make
src/scripts/shells/create_ipcs.sh - No such file or directory
Cannot access
/usr/people/jhickey/temp/grass/dist.mips-sgi-irix6.5/dev/create_ipcs.sh:
No idea how to fix 3. Just a report.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
subject 'unsubscribe grass5'
Justin,
Re #3. See Huidae's message. He had trouble adding the renamed file to the
src/scripts/shells directory. It looks like this has been fixed. I've just
downloaded but haven't tested yet.
Last night I ran into this problem and sent a message to Huidae off line, which
he fixed almost immediately - by renaming the script file. I had already tested
his script file and it ran correctly, it just needed to be renamed.
Update the src/scripts/shells directory and this should be resolved.
Malcolm
Justin Hickey wrote:
Hello all
Cannot access
Sincerely,
Bangkok, Thailand
Hi Malcolm
Malcolm Blue wrote:
Justin,
to the src/scripts/shells directory. It looks like this has been
fixed. I've just downloaded but haven't tested yet.
line, which he fixed almost immediately - by renaming the script file.
I had already tested his script file and it ran correctly, it just
Yep you are right. I did a complete update just before he updated the
file and I missed his update. Thanks.
Sincerely,
Bangkok, Thailand
Justin,
I see in a later message that you have already updated and tested successfully.
Ignore my earlier post.
Malcolm
Malcolm Blue wrote:
Justin,
Malcolm
> Hello all
> Cannot access
> Sincerely,
> Bangkok, Thailand
