Dear list,
I would like to export several rasterfiles (channels R,G,B,..) in one ERDAS/IMG file with GDAL. Is this possible?
r.out.gdal is working, but I can't find an option how to do this in the manual pages. Does anybody has an idea?
thanks
Otto
Otto Dassau wrote:
Dear list,
Otto,
I did a quick check of r.out.gdal and it does not seem to support outputting
more than one raster layer at a time to an output file even though I can see
that would be highly desirable. Likely it should offer an option to export
a "group" as that is the equivelent to a stack of image bands in GDALs data
model.
Given that it does not, it seems you might have to do this all rather
indirectly. One approach is to output individual rasters and then composite
them with an external application like OpenEV or within Imagine itself.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Programmer for Rent
On Tue, Aug 31, 2004 at 01:05:51PM -0400, Frank Warmerdam wrote:
Otto Dassau wrote:
>Dear list,
>ERDAS/IMG
>manual
Otto,
model.
Frank,
this could be added easily. But I don't know how to tell 'gdal_translate'
about it.
The docs only mention single-file input:
http://www.remotesensing.org/gdal/gdal_utilities.html#gdal_translate
As I also need that functionality, I'll add it once I have understood
the gdal_translate procedure...
Markus Neteler wrote:
Frank,
about it.
Markus,
gdal_translate doesn't support multiple input files. Holy cow! r.out.gdal
is just a script! OK, that isn't news to you but it is to me. I will add
writing a C r.out.gdal to my TODO list.
In the meantime, I don't think it will be easy to do from within GRASS.
BTW, before I forgot that gdal_merge.py can stack input files into seperate
bands if given the -seperate switch. So for anyone with a GDAL build that
includes python support you could export the various bands to standalone
files and then merge them into an RGB composite with:
gdal_merge.py -o out.img -of HFA -seperate band1.img band2.img band3.img
Best regards,
Isn't it possible to simply use GRASS groups, which are represented
as multiband in GDAL?
Radim
> Frank,
> about it.
Markus,
>> composite them with an external application like OpenEV or within
>> Imagine itself.
Best regards,
>Frank,
>about it.
Markus,
Hooray Was hoping for that a long time (I tried myself a bit but failed).
>>composite
Thanks for the hint, I was't aware of that flag yet.
(so I could mess up my script a bit more)
grass.itc.it/mailman/listinfo/grass5
Radim,
I am a moron. Yes, I think you are right. The script might need to be
changed a bit to allow selecting groups, but it should be a minor change.
Best regards,
