I have built a Cygwin version using source code checked
out on February 19, 2001. As with all of the builds, the
source is checked out into a new directory, a configure
is done, and the build is started.
Since the builds have been very stable, that is, no hand
tweaking to make them build, I have been building and
trying other software such as tcl, odbc, and postgresql.
I tried the tcltkgrass and the $window number is not
defined. It fails on line 1158 of gui.tcl; can anyone
give me some insight as to why it fails?
subject 'unsubscribe grass5'
On Mon, Feb 19, 2001 at 03:00:36PM -0700, John Huddleston wrote:
Markus, (List)
thanks for the new build. Does it use IPC or already sockets?
And so on for each window. The $window variable uses the lines that
start with "Window". I'm not sure if this command exists in Cygwin or
not. Maybe there is another alternative method to find the window id,
not sure though.
Sorry I couldn't be of better help.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
Do you have a recommendation for configure for Cygwin?
John
----- Original Message -----
From: "Markus Neteler" <neteler@geog.uni-hannover.de>
To: <grass5@geog.uni-hannover.de>
Sent: Tuesday, February 20, 2001 2:18 AM
Subject: Re: [GRASS5] February 19, 2001 Cygwin build
John,
> Markus, (List)
Sorry, no idea. Perhaps someone else?
to:
On Tue, Feb 20, 2001 at 12:49:45PM -0700, John Huddleston wrote:
Markus, (Anyone)
It was configured --with-ipc
It'd be helpful if you could tell us how/if GRASS works using the
--with-socket variant.
Eric G. Miller <egm2@jps.net>
John
To: "grass5" <grass5@geog.uni-hannover.de>
Sent: Tuesday, February 20, 2001 6:56 PM
> Markus, (Anyone)
I just built from yesterday's CVS source on Win98, using sockets.
I was wondering if anyone else is getting the following problem - when I try
to open the HTMLMAP and CELL drivers I get:
GRASS-GRID > d.mon CELL
Graphics driver [CELL] started
Wait for 'READY'
READY
ERROR: In SWITCHER.c: G_sock_listen() got error The descriptor is a file,
not a socket
Socket is already in use or not accepting connections.
Use d.mon to select a monitor
Problem selecting CELL. Will try once more
Mike Thomas
To: grass5 <grass5@geog.uni-hannover.de>
Sent: Wednesday, 21 February 2001 1:02 PM
Eric, (Grass list)
OK, will do tomorrow.
John
> > Markus, (Anyone)
write to:
to:
From my experience trying to run the XDRIVER on Win98 I suspect your problems are caused by poor process management with Cygwin/Win98. XDRIVER and CELL run OK with Cygwin/WinNT, but I was unable to get the XDRIVER running on Win98 (I didn't try CELL at the time). Since both use fork(), I suspect they are doing something in that implementation that doesn't work reliably on Win 98.
When I start the XDRIVER using d.mon start on WinNT, the XDRIVER.exe is listed in the process list from the ps command. When I tried the same thing on Win98, it seemed to start the XDRIVER, but then issued some error messages (IPC version messages). The ps command did not list the XDRIVER.exe process.
Unfortunately a number of Cygwin API calls work on WinNT that don't work on Win98. I'm able to run both IPC and socket version of GRASS on WinNT.
Sorry I couldn't give you better news, but I think its a cygwin/Win98 problem.
Malcolm
Mike Thomas wrote:
Wait for 'READY'
READY
not a socket
Mike Thomas
Eric, (Grass list)
John
Markus, (Anyone)
write to:
to:
---------------------------------------- If you want to unsubscribe from GRASS Development Team mailing list write to:
On Thu, Feb 22, 2001 at 09:21:03AM +1000, Mike Thomas wrote:
Wait for 'READY'
READY
not a socket
I suspect the CygWin port to the 9x series doesn't support unix sockets.
I tried to check at http://sources.redhat.com/cygwin, but the server is
not responding at the moment...
