Fedora Core 3 spec file for building GRASS 6.0 RPMs now in CVS thanks to
the work of Craig Aumann.
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/rpm/fedora/grass.spec
could those in the know please test, prod, inspect, and comment?
also have a look at the INSTALL.TXT file:
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/rpm/fedora/INSTALL.TXT
This should work around GRASS bug #2526 by not using readline.
https://intevation.de/rt/webrt?serial_num=2526
one question from me is the use of /usr/local, but I don't know the ways
of Fedora.
thanks,
Hamish
