[GRASS5] fifos not created
On Sun, Feb 04, 2001 at 09:40:32PM -0800, Jeshua Lacock wrote:
> OK, So I downloaded beta 11 and deleted the old, did a "make
> distclean" and so on. And after it compiles I tried to start a
> monitor and I get the message;
> GRASS 5.0beta11 > d.mon start=x0 Sorry,
> </usr/local/grass5/dev/fifo.1a> not available Have GRASS
> adminstrator check etc/monitorcap file Can't stat
> /usr/local/grass5/dev/fifo.1a Problem selecting x0. Will try once
> more Can't stat /usr/local/grass5/dev/fifo.1a
> So I tried to inspect the fifo and found that there is no dev
> directory. Instead there is a dev script. I tired moving the script
> and running it and it creates the fifo's but then I still get the same
> message.
> It seems odd to me. Beta 11 pre2 did not do this.
> The only difference between this build and pre2 is one there are new
> sources I downloaded today and two I am now running Xfree86 4.02 with
> the Aqua patch, but I do not suspect two as being the problem.
Something got puckered, not sure if it's fixed yet in CVS, but it has
something to do with the README.ipc thingy. Anyway,
#! /bin/sh
for i in 1 2 3 4 5 6 7 8 9 10 ; do
  mkfifo -m 0666 "fifo.""$i""a"
  mkfifo -m 0666 "fifo.""$i""b"
done
If you don't have mkfifo, use 'mknod -m 0666 "fifo.""$i""a" p'
You could also try running ./configure --with-fifo explicitly...
I fixed Makefile.in and README.ipc to create "dev" directory before copying
anything into this directory.
Huidae Cho
subject 'unsubscribe grass5'
> > message.
> #! /bin/sh
> done
Huidae Cho
Hi Huidae,
shall I release an updated source code package (the binaries are not
affected if using your patch!)?
Hi Markus
If you do, then please wait for my changes that implement a binary
uninstall script (grass5uninstall). Hope to get it done today.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
On Mon, Feb 05, 2001 at 05:11:12PM +0700, Justin Hickey wrote:
Hi Markus
O.k. fine. I'll keep watching the CVS channel :slight_smile:
From neteler@geog.uni-hannover.de Mon Feb 5 19:09:14 2001
> From: "Eric G . Miller" <egm2@jps.net>
> > > message.
> > #! /bin/sh
> > done
> Hi all,
> Regards,
> Huidae Cho
Hi Huidae,
It's not a big change, so i think it's better to announce how to fix this
install problem. Just get new Makefile.in and README.ipc and rerun make.
That's all.
Yours,
Huidae Cho
From neteler@geog.uni-hannover.de Mon Feb 5 19:24:52 2001
> Hi Markus
That sounds good. It's worth releasing new package after this change.
Huidae Cho
